seat belt relay, seat belt relay |
porscheteck914 |
Apr 5 2023, 08:46 PM
Newbie Group: Members Posts: 38 Joined: 23-March 23 From: n.c. Member No.: 27,247 Region Association: North East States |
Hi Does anyone have pictures of the seat belt relay board and wires behind the seat of 1974 914 ? Or were I can get a wire diagram of this . Some idjut hacked mine up. Would like to fix this . thanks kindly
Garland |
Apr 5 2023, 08:56 PM
Restoration Fanatic Group: Members Posts: 1,398 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest |
wonkipop |
Apr 6 2023, 01:48 AM
Advanced Member Group: Members Posts: 4,670 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
Hi Does anyone have pictures of the seat belt relay board and wires behind the seat of 1974 914 ? Or were I can get a wire diagram of this . Some idjut hacked mine up. Would like to fix this . thanks kindly why do want to fix it? i took mine out of action back in 92. the relay was causing all sorts of problems once it heated. like no start. i got sick of pushing the car in reverse on my own to jump start it. you are better off without it. trust me. or are you trying to fix up a bigger fark up that someone did trying to solve this problem? |
friethmiller |
Apr 6 2023, 07:47 AM
Senior Member Group: Members Posts: 713 Joined: 10-February 19 From: Austin, TX Member No.: 22,863 Region Association: Southwest Region |
friethmiller |
Apr 6 2023, 07:56 AM
Hi Does anyone have pictures of the seat belt relay board and wires behind the seat of 1974 914 ? Or were I can get a wire diagram of this . Some idjut hacked mine up. Would like to fix this . thanks kindly why do want to fix it? i took mine out of action back in 92. the relay was causing all sorts of problems once it heated. like no start. i got sick of pushing the car in reverse on my own to jump start it. you are better off without it. trust me. or are you trying to fix up a bigger fark up that someone did trying to solve this problem? Agree! I actually never installed either of the relays into this plastic board. I didn't see any reason to have it hooked up. I just wanted wiring put back to original. |
porscheteck914 |
Apr 6 2023, 06:12 PM
porscheteck914 |
Apr 6 2023, 06:20 PM
wonkipop |
Apr 6 2023, 08:38 PM
Hi Does anyone have pictures of the seat belt relay board and wires behind the seat of 1974 914 ? Or were I can get a wire diagram of this . Some idjut hacked mine up. Would like to fix this . thanks kindly why do want to fix it? i took mine out of action back in 92. the relay was causing all sorts of problems once it heated. like no start. i got sick of pushing the car in reverse on my own to jump start it. you are better off without it. trust me. or are you trying to fix up a bigger fark up that someone did trying to solve this problem? i had a very good auto electrician sort mine out 30 years ago back here in australia after i got the car home. we wired in a hidden kill switch thats hidden under the passenger seat (now drivers seat). the rest of it is all still there. didn't bother to remove it. relays and all. he just wired around it. he was one of the few blokes here who could work out what was going on. he'd struck the same problem in some privately imported 74+ US muscle cars that folks had brought it so he went for it straight away. i still remember he asked me what year it was. i said 74. he went straight to the seat belt couplings and traced the wires. he had the passenger seat out in no time and it was all solved in about 15 minutes. no one else here had a clue what was causing the hot start problem. which wasn't really a hot start so much as a hot relay after you had the ignition on for a while. (IMG:style_emoticons/default/headbang.gif) still remember it well. (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 5th January 2025 - 12:16 AM |
