rear brake line tee, pros and cons |
r_towle |
Aug 12 2005, 08:06 PM
Custom Member Group: Members Posts: 24,598 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Replacing the rear proportioning valve with a tee fitting???
Will this make is brake more during autocross? And, is this a standard plumbing tee, or is it special??? Rich |
campbellcj |
Aug 12 2005, 08:40 PM
I can't Re Member Group: Members Posts: 4,555 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
Tons of info in the archives (search) -- first questions are, do you have stock brakes? Tires? Track, autox or street car?
The tee itself is a brake specific part; most use a VW tee available for like $10-20 at typical bus/bug shops. |
r_towle |
Aug 12 2005, 08:58 PM
I have searched, no quality results...
We need a better search engine. Thanx for the response. Rich |
Aaron Cox |
Aug 12 2005, 09:00 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
Rich,
I just installed one, got it from someone, who bought it from James Adams.... available at ANY big shop for under 10 bucks... think of it as a P -valve that is wide open.... gives MORE power to the already undersized rear brakes (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
r_towle |
Aug 12 2005, 09:01 PM
is this tee fitting a stock part on a beetle???
I have two out in the barn...If I can steal it, that would be good. Rich |
SirAndy |
Aug 12 2005, 09:02 PM
Resident German Group: Admin Posts: 41,707 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
stock brakes, no T ... bigger brakes and MC, the T will give you more bias towards the rear, which is a gud thing as bigger brakes tend to favor the front. key is, you want the front to lock up just a millisec before the rears and not the other way round. the "Tee" can be had at every VW-Bug shop for $5+ ... (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Andy |
Aaron Cox |
Eric_Shea |
Aug 12 2005, 09:06 PM
PMB Performance Group: Admin Posts: 19,279 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Mark your calendar... I agree with Andy (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif)
Marv's3.6six |
Aug 12 2005, 09:19 PM
Actual member 7" Group: Members Posts: 695 Joined: 22-November 04 From: Huntington Beach, Ca. Member No.: 3,165 Region Association: Southern California |
An adjustable proportioning valve is the best way. I am doing one in cab like the pic. The trick has been finding one with all metric connections, found at PMS.
Attached image(s) |
Aaron Cox |
Aug 12 2005, 09:22 PM
Marv,
why go with the handle type when it only has ~6 positions, why not use the knob type with infinite adjustability???? AA |
Marv's3.6six |
Aug 12 2005, 09:25 PM
Cuz the range of adjustment is the same in both types of P valves, this type lets you know where your at by touch or visual.
Aaron Cox |
Aug 12 2005, 09:26 PM
good to know. thanks marv -Aaron |
SirAndy |
Aug 12 2005, 09:31 PM
except, unless you've got HUGE rear brakes, we always end up running the adjustable proportioning valve "full open" which is exactly what the $5 "T" does for you ... (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif) Andy |
Marv's3.6six |
Aug 12 2005, 09:41 PM
I'm runnin the new Brembo GTP Lightweights, they are beeeeeg.
SirAndy |
Aug 12 2005, 09:42 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/wub.gif) they sure are ... (IMG:http://www.914world.com/bbs2/html/emoticons/thisthreadisworthlesswithoutpics.gif) |
Lo-Fi Version | Time is now: 26th June 2024 - 06:00 AM |
