74forsche |
Newbie ![]() Group: Members Posts: 49 Joined: 6-November 20 From: castle rock washinton Member No.: 24,848 Region Association: Pacific Northwest ![]() |
https://w3dparts.com/?product=914-headlight-delete
W3dparts has a headlight delete kit ready! If you are looking for a lightweight option that can remove the old pop ups...give them a look! |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,811 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
I love the pop ups.
ssstikircr |
Member ![]() ![]() Group: Members Posts: 211 Joined: 11-January 09 From: Fair Oaks, Ca Member No.: 9,920 Region Association: Northern California ![]() |
It would look better with some kind of lens over the lights
74forsche |
mepstein |
It would look better with some kind of lens over the lights They look much better in person. They are a huge upgrade in light and function and if deleting entire headlight bucket, significant weight savings! Headlight motors are 4.5lbs. Probably another 2 lbs for headlight and sheetmetal. 13 lbs. total. Get GE truck-lights if you want mind blowing headlights. 5 minute swap. |
74forsche |
It would look better with some kind of lens over the lights They look much better in person. They are a huge upgrade in light and function and if deleting entire headlight bucket, significant weight savings! Headlight motors are 4.5lbs. Probably another 2 lbs for headlight and sheetmetal. 13 lbs. total. Get GE truck-lights if you want mind blowing headlights. 5 minute swap. You need to reweigh some stuff there. |
74forsche |
So the pop up headlight and motors weigh in at 30lbs. The sheetmetal removal would be at least 20lbs...so 50lb weight reduction is there
74forsche |
Theses housings are polycarbonate carbon fiber. Light and strong. They can be sanded and painted or clear coated. The lower bulb is low beam. The upper is high beam. Both are lit for high beam. The upper bulb is also the blinker....as these lights are dual function. The small middle bulb is the running light. Our focus with these is for restomods, v8 conversions, and track cars. The lighting improvement is significant.
74forsche |
We will shortly have an entire tail light housing replacement. To compliment the headlights. Again polycarbonate carbon fiber. Bolt in and connect !
Attached thumbnail(s) ![]() |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,236 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
What is the thing with the orange handle?
74forsche |
74forsche |
These deletes can be used With the stock headlight as well. If you are just want to add better lighting and turn signal function.
jim_hoyland |
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,655 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California ![]() ![]() |
Very cool; innovative. (IMG:style_emoticons/default/smile.gif)
gtbarnes |
Newbie ![]() Group: Members Posts: 26 Joined: 9-July 13 From: nash,tn Member No.: 16,111 Region Association: South East States ![]() |
https://w3dparts.com/?product=914-headlight-delete W3dparts has a headlight delete kit ready! If you are looking for a lightweight option that can remove the old pop ups...give them a look! I cant get the link to work, I was really wanting to see the headlights! |
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,764 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
I have a pair and headlight delete hood..for sale...
I changed my mind.. here is the link..dgauto. https://3dgauto.com/products/custom-porsche...with-headlights |
Lo-Fi Version | Time is now: 2nd April 2025 - 11:04 PM |
