r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,598 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
76 2.0 Djet
What is the proper routing for the drivers side fuel supply line to the injector rail? Just going in to replace all engine bay lines and the driver side is laying on top of the motor, and does not seem right. What do others have? Rich |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,519 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
Mine lays on the engine as well.
emerygt350 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,202 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States ![]() |
Yep, but not right on it... Mine goes up over the oil fill etc.
r_towle |
Same, just seems kind of sloppy, but okay Dokey
914werke |
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,192 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest ![]() ![]() |
OG there was a plastic like sleeve over the rubber line presumably to protect against heat or chaffing.
wonkipop |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,440 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille ![]() ![]() |
74 L jet. similar i'm guessing
as @914werke says - fuel line runs inside plastic sleeve which clips to side of front inlet runner. clips are spot welded to runner. ![]() |
Lo-Fi Version | Time is now: 26th June 2024 - 09:39 AM |
