914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,924 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
Thought I would share this with board
3 types of cable pulls Original, Aftermarket, 356 Aftermarket spacer VW cone screw instead of Set Screw Two different clutch cables Attached image(s) ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
mgphoto |
"If there is a mistake it will find me" ![]() ![]() ![]() Group: Members Posts: 1,341 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California ![]() |
The center is the factory replacement for the black plastic version which tended to loose the nubs.
914Sixer |
Black plastic on left is the bad one. Center one is metal, so is 356.
mgphoto |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,599 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
interesting seeing the differing lengths of the spacer.
rich |
Lo-Fi Version | Time is now: 1st July 2024 - 10:11 AM |
