> Engine Mount Restoration (with pics)
friethmiller
post May 8 2023, 08:11 AM
After removing the engine mount from my passenger side (hell hole), I decided it might be fun, as a side project, to try and restore instead of replace this item. Not sure if anyone else has ever tried this (I'm sure they have) but I'm thinking... why not. Famous last words! So, here we go....
View of the engine mount pulled out of my very rusted out '74 LE. Note the rust (red arrow) on the back.
Beginning the process of drilling out the many spot welds around this two-piece, 14 gauge metal part.
friethmiller
post May 8 2023, 08:15 AM
After a bit of drilling, I was finally able to remove the two pieces. These went into a rust removing bath before each piece was individual restored.
Here's the bottom piece with the three facets replaced. I actually used POR-15 in this area before the later reassembly.
Removal of the rusted metal from the top part of the second piece.
friethmiller
post May 8 2023, 08:18 AM
After cutting the new 14 gauge sheet metal, measurements where made and a metal brake was used to create the three simple 90 degree bends.
Here's the part welded on. Note the rust holes on the other section.
The bottom section with the metal replaced and welded in.
friethmiller
post May 8 2023, 08:21 AM
Final welds for the filter mount and clean up before final assembly.
Joining the two pieces. This process was simple but took a lot of time. Had to keep the heat down, especially in the front section that you see here.
friethmiller
post May 8 2023, 08:23 AM
Final View with rust preventive paint and weld-thru primer. Not too bad for an amateur. This thing is now rock solid!!
Van B
post May 8 2023, 12:40 PM
While I think you did a great job, you have also confirmed that I would choose replacement lol
930cabman
post May 8 2023, 12:47 PM
Looks great, want to do a couple for me?
Keep up the good work
Root_Werks
post May 8 2023, 12:56 PM
Village Idiot
Turned out nice! (IMG:style_emoticons/default/smash.gif)
friethmiller
post May 8 2023, 01:51 PM
QUOTE(Van B @ May 8 2023, 01:40 PM) *
Van, you made me laugh! (IMG:style_emoticons/default/lol-2.gif) Agree, I think "replacement" IS the better option here but I wanted to see how it would go. This was just a little distraction from my massive Hell Hole reconstruction project that is on-going. Plus, I found the absolute limit for my metal brake. With 14 gauge sheet metal, I felt like I was going to rip the brake out of the work bench it's mounted on.
- Lo-Fi Version Time is now: 19th April 2025 - 11:49 PM
