> /6 Heat exchanger, repair and installation
michel richard
post Aug 14 2005, 01:23 PM
It's a little rainy today, in Montreal, so I'm getting a few things done. The original /6 heat exchangers I got from Jon Lowe were in pretty good condition, except that one had a hole in it.
So I brazed in a patch. I like brazing for this sort of work because it's easy and leaves a low profile patch.
Unfortunately, I left a couple of little gaps after the first go-around.
michel richard
post Aug 14 2005, 01:25 PM
So I went over it again with the braze rod. Another advantage is that repairs are easy to make when I don't get it quite right the first time . . .
michel richard
post Aug 14 2005, 01:26 PM
The result. This is as good as I can get it.
michel richard
post Aug 14 2005, 01:30 PM
On the green car, I currently run headers, modified to provide heat to the MFI warm up regulator. The plan is to install the heat exchangers very soon so that I can have the exhaust I plan to use long term before the PMO carbs get the final dial-in.
I also plan to show the rest of the heat exchanger install in this thread.
See for the PMO chapter.
http://www.914world.com/bbs2/index.php?act=...=ST&f=2&t=36529
Michel Richard
michel richard
post Aug 17 2005, 12:59 PM
Back from the chrome shop. I simply had them dip the heat-exchangers and sand blast them. Quite a bit of pitting, and I found hole in the header itself. Nothing that can't be fixed quite easily.
Michel
michel richard
post Aug 17 2005, 01:00 PM
Paint drying !
- Lo-Fi Version Time is now: 7th January 2025 - 09:47 PM
