Allan |
Teenerless Weenie ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California ![]() |
I probably asked this and got an answer yesterday but can't remember.
I have stock '75 brakes drilled for a 5 lug conversion. Question #1: Will stock /6 rotors bolt right on? Question #2: What does it cost to have stock rotors drilled to 5 lug? Thanks... |
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California ![]() |
just get the /6 rotors.... they slide right on... about 20 bucks more.......
and you dont need to redrill em every new rotor..... |
Eric_Shea |
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,279 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains ![]() ![]() |
Your "brakes" are drilled? I think we're talking about a few things here... If your rear "hubs" are drilled and studded for 5-lug then P-Admin is correct. Get -6 rotors for the rear. If your front "rotors" are drilled and they're warped or worn then you'll need to either drill a new set (we have them in stock drilled and studded for that car $295 for the pair) or put a 911 front end on your car. Stock -6 front rotors will not work unless your car has been upgraded to a 911 front end. |
Series9 |
Lesbians taste like chicken. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,444 Joined: 22-August 04 From: DeLand, FL Member No.: 2,602 Region Association: South East States ![]() |
jim_hoyland |
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,334 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California ![]() ![]() |
Was your e-brake light working ? It was good to see you Saturaday in San P-
Lo-Fi Version | Time is now: 26th June 2024 - 10:20 AM |
