> A nice 2.0 rebuild
Zuffenwerker
post Jul 26 2023, 04:01 PM
I recently acquired my first 914. It’s a 75 2.0 that is mostly original. Here are some photos of my recent rebuild for those who would like to browse!Attached Image Attached Image
Original cylinders bored 1mm over. Keith black mercury pistonsAttached Image
Neway valve job SI valvesAttached Image
Yellow zinc everything because I LIKE it!!Attached Image
Gloss powdercoatAttached Image Attached ImageAttached ImageAttached Image[attachmentid=882
858]Attached Image
rfinegan
post Jul 26 2023, 05:20 PM
LOTS of nice stuff going on here...
-Cheers
Montreal914
post Jul 26 2023, 08:56 PM
Nice looking engine! (IMG:style_emoticons/default/smile.gif)
Looks like your gearbox shifter input lever (with the sphere) was installed 180 degree off maybe? (IMG:style_emoticons/default/confused24.gif)
Zuffenwerker
post Jul 27 2023, 07:05 AM
QUOTE(rfinegan @ Jul 26 2023, 06:20 PM) *
-Cheers
Do you recognize those NICE original heat exchangers…? Thanks so much for them! Have all is well in Clayton!
Daniel
Zuffenwerker
post Jul 27 2023, 07:07 AM
QUOTE(Montreal914 @ Jul 26 2023, 09:56 PM) *
Thank you and yes to the shift lever haha figured that one out as soon as I tried to hook up the shift rod…914 newb
Shivers
post Jul 27 2023, 07:19 AM
Looks great.
Zuffenwerker
post Jul 27 2023, 07:57 AM
https://docs.google.com/spreadsheets/d/1Vc6...dit?usp=sharing
Here is a link to the engine specs if anyone is interested. Compression came out to about 8.9:1.
I will post the dyno sheet here once it hits the chassis dyno
Here are some more shots of the projectAttached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image
rfinegan
post Jul 27 2023, 08:00 AM
HE cleaned up nice...well done
CCE
post Jul 27 2023, 08:56 AM
CCE
Looks awesome!
I was not able to hold myself and maintain the originality… temptation was too much
Now its a 2.2 with 44mm webers, port polish and blanced, with a mild hot cam and the webers with conical velocity stacks… (a hooligan, lots of fun), but your pictures make me think…
jc73-914
post Jul 27 2023, 02:28 PM
very nicely done ... (IMG:style_emoticons/default/beerchug.gif)
CCE
post Jul 27 2023, 08:21 PM
CCE
QUOTE(Zuffenwerker @ Jul 27 2023, 07:57 AM) *
We have the same piston brand…
Dave_Darling
post Jul 28 2023, 05:56 PM
914 Idiot
Do yourself a favor and ditch those heat exchangers. They are really very horrible. I mean, they look great, but their design is pretty terrible. The earlier ones may not be exactly amazing for power, but they are a lot better than these. Two pipes that join straight out of the head, no thought to equal lengths, make an almost immediate tight 180-degree turn? That flies directly in the face of pretty much all the principles of good exhaust design.
If you want heat, use the later-style 2.0 exhaust, or SSIs. If you don't need heat, talk to Chris at Tangerine Racing.
Oh, and you'll need to pull the gear selector (and side shift console) off the gearbox and flip around either the rake or the knob part, because they're 180 degrees off from where they should be.
--DD
- Lo-Fi Version Time is now: 26th February 2025 - 04:43 PM
