> Which Springs would you intall?, The never ending BB take apart/redo continues
jhynesrockmtn
post Aug 23 2023, 06:41 PM
I am refreshing the rear suspension on my BB. Yet another project I hadn't really planned on but here we are.
I now have everything I need to reinstall the rear trailing arms and shocks. The arms got painted new bushings and bearings (thanks @iankarr and 914rubber). New Koni sports from Paragon (thanks Jason), PMB rebuilt brake calipers (thanks Eric).
I found some new/old Weltmeister SP100's in a box of parts a PO had bought for another project car I have. See the photos. The only mark on the springs that came off the BB are a redish paint on each coil. The car did sit lower than stock by my eye. See photo. I don't know much about the SP100 but they do look pretty :-)
Would you go all the way and install the "new" springs. I realize 100lbs are stiffer than stock. I could always go back if I don't like the ride. The koni's aren't full coil overs but have a bit of ride height adjustment. The middle clip position matches the old Koni shocks I removed. The springs do sit 2 to 3 mm taller with no compression.
914werke
post Aug 23 2023, 07:45 PM
Id run um (IMG:style_emoticons/default/smile.gif)
914Sixer
post Aug 23 2023, 08:01 PM
Old school Orange Koni, 100 # springs
Front yard mechanic
post Aug 23 2023, 08:27 PM
Use the new shocks and the sp100s and move the clip down
scallyk9
post Aug 23 2023, 08:52 PM
When I redid the rear suspension on my BB, I used the very same Weltmeister 100# springs but went to Bilstein shocks because they would have been available as an option.
My '74 3.2L conversion does have the yellow adjustable Koni's however but a much higher spring rate other changes won't allow me to make a valid comparison.
The 100# rear springs on my BB did not really affect the "feel" ride but I do feel they were a benefit. That car is set front and rear at stock ride height. I wouldn't hesitate to use them.
rfinegan
post Aug 24 2023, 07:02 AM
New Springs for sure, unless its concourse judged
Shivers
post Aug 24 2023, 08:38 AM
I have the 140 lbs on my car, the 100’s should be nice for play and still have some give.
Root_Werks
post Aug 24 2023, 08:49 AM
Village Idiot
QUOTE(914Sixer @ Aug 23 2023, 07:01 PM) *
I'm running this combo on a 914-6 and really like it for street driving. Granted a 914-6 will be a little heavier, but would think it will still be a good street combo for most 914's.
I turned my Koni's 1-turn less than full dampen.
windforfun
post Aug 25 2023, 12:25 PM
100 lb Weltmeisters.
(IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif)
CCE
post Aug 25 2023, 01:16 PM
CCE
I installed the 914rubber springs 100Lb, with Bilsteins B6 and they work perfect! Firm but not to a discomfort level. And Mexico streets are I can testify the worst all over, I also don't have stabilizer bars, which may also come to affect ride (wish I did).
Mikey914
post Aug 25 2023, 02:23 PM
The rubber man
100lb is the way to go. We have a 140progressive160 if you are driving more agressive, but if you do that, Bilstiens are the way to go.
- Lo-Fi Version Time is now: 25th November 2024 - 06:53 AM
