Foggy gauge lenses, Easy cure or send to CA? |
StarBear |
Sep 12 2023, 06:26 AM
Senior Member Group: Members Posts: 1,939 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States |
Console gauges get foggy in humidity, especially cool humidity. Any solution other than sending to CA? Original glass lenses. Don’t have bezel tool. (IMG:style_emoticons/default/sad.gif)
Rusty |
Sep 12 2023, 06:33 AM
Wanted: Engine case GA003709 Group: Admin Posts: 7,943 Joined: 24-December 02 From: North Alabama Member No.: 6 Region Association: Galt's Gulch |
I've been told condensation is a symptom of residue on the inside of the glass.
Reach out to Bill. I bet he can make your gauges sparkle and refresh your needles. Trust me. Quality work at a fraction of the insane big shop prices. |
87m491 |
Sep 12 2023, 06:46 AM
Member Group: Members Posts: 276 Joined: 29-July 12 From: Portland, the original! Member No.: 14,731 Region Association: North East States |
Superhawk996 |
Sep 12 2023, 07:01 AM
914 Guru Group: Members Posts: 5,955 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Gauges are not sealed. A gauge rebuild isn’t going to prevent future condensation when temperatures and relative humidity encourage it.
Smoking was very common in the 70s and leaves behind a smoke film. Likewise repeated condensation and off-gassing from vinyl and plastics will leave a film. I have seen gauges with extreme cloudy film inside the glass that can only be cleaned by disassembling the gauge. Your pictures seem to look more like this to me than simple condensation. |
StarBear |
Sep 12 2023, 07:25 AM
"Bill"? Do tell us more. I've been told condensation is a symptom of residue on the inside of the glass. Reach out to Bill. I bet he can make your gauges sparkle and refresh your needles. Trust me. Quality work at a fraction of the insane big shop prices. (IMG:style_emoticons/default/agree.gif) |
Rusty |
Sep 12 2023, 07:27 AM
Paging @jbell959 to the Aubergine courtesy phone...
StarBear |
Sep 12 2023, 07:29 AM
Gauges are not sealed. A gauge rebuild isn’t going to prevent future condensation when temperatures and relative humidity encourage it. Smoking was very common in the 70s and leaves behind a smoke film. Likewise repeated condensation and off-gassing from vinyl and plastics will leave a film. I have seen gauges with extreme cloudy film inside the glass that can only be cleaned by disassembling the gauge. Your pictures seem to look more like this to me than simple condensation. When not humid a bit of haze on the inside of the temp gauge that could use cleaning anyway. Really showed up this morning. Garage kept, of course! |
bkrantz |
Sep 12 2023, 07:01 PM
914 Guru Group: Members Posts: 7,828 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
I cleaned my own. The crud on the inside of the glass was obvious, and worse with even a bit of condensation. It was too obvious to live with after I had the speedo apart (and cleaned that) and added a new oil pressure gauge to the console.
The ghetto method of removing and reinstalling the bezels is crude, but not visible from the front. |
StarBear |
Sep 13 2023, 08:17 AM
I cleaned my own. The crud on the inside of the glass was obvious, and worse with even a bit of condensation. It was too obvious to live with after I had the speedo apart (and cleaned that) and added a new oil pressure gauge to the console. The ghetto method of removing and reinstalling the bezels is crude, but not visible from the front. That would be helpful, @bkrantz . Any info or link on the ghetto method ? |
FlacaProductions |
Sep 13 2023, 08:56 AM
Senior Member Group: Members Posts: 1,638 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
I believe @bkrantz is referring to the method of putting the gauge face down on a towel or soft surface and using a small flat blade screwdriver to work your way around the back of the bezel, twisting the blade to uncrimp it.
Go slow until you get the feel - try a couple of different blades. Eventually, you'll be able to work the bezel off, remove the glass and give it a good clean. I use compressed air and wear rubber gloves when handling the glass. Pop the cleaned glass back in the bezel and work it back onto the face of the gauge. Place it face down on a cushioned surface and work your way around, putting the crimp back on. I like a fairly wide flat blade for this but you'll see what works. |
StarBear |
Sep 13 2023, 10:05 AM
Thanks! Will give it a try - slowly and carefully.
iankarr |
Sep 13 2023, 01:31 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,482 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
You can see the process here…
https://youtu.be/r3xJxEiIlIQ?si=nwg4X21VXHyLqfRD |
DC_neun_vierzehn |
Sep 13 2023, 02:04 PM
Member Group: Members Posts: 411 Joined: 16-November 20 From: Delaware Shore Member No.: 24,893 Region Association: MidAtlantic Region |
That's John Bell (not Bill), as I recall. He did a combo gauge for me. He and his son do amazing gauge work for very reasonable prices. Super easy to work with. |
StarBear |
Sep 13 2023, 03:19 PM
Thanks! Hope to hear from John bell, too, just in case. |
StarBear |
Sep 13 2023, 03:29 PM
I think even I can do that, Ian. Great video, as usual! |
bkrantz |
Sep 13 2023, 07:28 PM
I cleaned my own. The crud on the inside of the glass was obvious, and worse with even a bit of condensation. It was too obvious to live with after I had the speedo apart (and cleaned that) and added a new oil pressure gauge to the console. The ghetto method of removing and reinstalling the bezels is crude, but not visible from the front. That would be helpful, @bkrantz . Any info or link on the ghetto method ? Here's a photo from when I did my tach. I tried to be patient and slow, and VERY gradually pry up the edge of the retaining ring. After cleaning the glass, I crimped the edge back the same way. Attached thumbnail(s) |
bkrantz |
After installation.
Lo-Fi Version | Time is now: 20th June 2024 - 11:41 PM |
