Why?, Most things on this car |
NARP74 |
Sep 21 2023, 02:33 PM
Senior Member Group: Members Posts: 1,307 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
Why would someone do this? Planning ahead for some rear suspension work and I find this. I am having a hard time thinking what they were trying to do. Am I screwed?
DennisV |
Sep 21 2023, 02:49 PM
Senior Member Group: Members Posts: 579 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California |
Why would someone do this? Planning ahead for some rear suspension work and I find this. I am having a hard time thinking what they were trying to do. Am I screwed? I am guessing someone overtightened and it snapped. (IMG:style_emoticons/default/welder.gif) The only thing I could think to do is weld a bolt to that center rod section so you have something to hold against. Perhaps someone more clever than I am has a better suggestion. |
GregAmy |
Sep 21 2023, 02:58 PM
Advanced Member Group: Members Posts: 2,414 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
If you put a really good impact gun and 6-point impact socket on it it'll probably spin right off.
If the shaft spins and it doesn't come off, you can go underneath with vice grips on the shaft. Clearly, you're planning to replace that? |
NARP74 |
Sep 21 2023, 03:05 PM
It looks cut to me. The other side looks the same. No idea why.
I was not planning on replacing it until I took the hat off and saw it. This changes my plans and cost quite a bit. |
Superhawk996 |
Sep 21 2023, 03:12 PM
914 Guru Group: Members Posts: 6,630 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Like most things DAPO’s do, you’ll never figure out what they were trying to “fix”.
Just keep moving forward. Both suggestions above are good advice. |
Mike9142.0 |
Sep 21 2023, 03:26 PM
Member Group: Members Posts: 219 Joined: 29-January 03 From: Phoenix, AZ Member No.: 208 Region Association: Southwest Region |
The shaft on some rear shocks can be very long. My guess is that they were trimmed down so the the top was not damaged when stored is the trunk.
mepstein |
Sep 21 2023, 03:27 PM
914-6 GT in waiting Group: Members Posts: 19,678 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
If you put a really good impact gun and 6-point impact socket on it it'll probably spin right off. If the shaft spins and it doesn't come off, you can go underneath with vice grips on the shaft. Clearly, you're planning to replace that? Yep. Rattle gun for the win. |
Root_Werks |
Sep 21 2023, 03:44 PM
Village Idiot Group: Members Posts: 8,525 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Looks like a home made lock nut, ground down to "lock" the nut.
Yup, impact gun should zip that off pretty quick. |
930cabman |
Sep 21 2023, 04:00 PM
Advanced Member Group: Members Posts: 3,803 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
Why would someone do this? Planning ahead for some rear suspension work and I find this. I am having a hard time thinking what they were trying to do. Am I screwed? Not screwed at all, when it's time to disassemble either impact or cut the nut off. How many other "surprises" are from the prior DAPO |
Geezer914 |
Sep 21 2023, 04:06 PM
Geezer914 Group: Members Posts: 1,805 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
What is that? Trying to figure where that is. Need an expanded picture.
burton73 |
Sep 21 2023, 04:17 PM
burton73 Group: Members Posts: 3,704 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
What is that? Trying to figure where that is. Need an expanded picture. I take it that's the top of a shock tower? Just with the carpets near it, I confused me. Somebody either used a hacksaw, or somebody used a grinder. Try to get it off of there or leave it there until you're forced to get it off. Bob B |
NARP74 |
Sep 21 2023, 04:41 PM
Top of the rear shock tower. So I have a fully carpeted trunk and someone takes a sawzall to the shock rods that are sticking out of the top of the nut. Make it make sense.
In my case it is DA2PO. I am finding things from both previous owners, or at least the shops they used too. I'll make a list sometime. |
Root_Werks |
Sep 21 2023, 05:19 PM
Don't forget there was a good number of years 914's were very affordable (cheap). Lots of Back-Yard-Bob's and their kids got a hold of 914's. Decades later, those "repairs" or "upgrades" need correcting.
NARP74 |
Sep 21 2023, 05:28 PM
This car has some high end upgrades. I don't agree with all of them, but someone wanted this to be a dream car, their dream, not mine. Some of the things I find just don't make sense.
bkrantz |
Sep 21 2023, 07:32 PM
914 Guru Group: Members Posts: 8,192 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
What brand rear shocks, and how old? They might be due for replacement anyway.
Gint |
Sep 21 2023, 09:33 PM
Mike Ginter Group: Admin Posts: 16,095 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
I have an impact that will probably take those off without too much trouble.
targa72e |
Sep 21 2023, 10:53 PM
Member Group: Members Posts: 278 Joined: 11-September 16 From: colorado Member No.: 20,392 Region Association: None |
No idea why thy did what they did. That said I use an impact on struts for removal (and sometimes instillation) so it would not really make a difference.
john |
NARP74 |
Sep 22 2023, 08:02 AM
As a test I put a hand wrench on it and they both loosened up easily. Not sure if that is a good thing or a bad thing. They are Bilstein shocks, no idea how old they are or how many miles they have on them. I'll take a closer look this weekend for a date code and model info if they are on there.
Lo-Fi Version | Time is now: 4th January 2025 - 12:34 PM |
