GWN7 |
King of Road Trips ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,280 Joined: 31-December 02 From: Winnipeg, MB, Canada Member No.: 56 Region Association: Northstar Region ![]() |
This is what caused the breakdown in Kelowna. Put the clutch in, backed up a hill, when to shift to neutral, pedal to the floor. Clevis spread and poped off the clutch pedal arm.
Attached image(s) ![]() |
GWN7 |
Tryed to straighten it and the arm broke. Took it over to a friend of my buddys daughter and he happened to have a full welding shop at home. He tigged it back together. Even painted it. Looked better than new.
Got home with the car and took the son for a ride and the same thing happened again. Bent and poped off again. This time I took the one off the 73 so I could drive. So far so good. But why did this happen? Attached image(s) ![]() |
GWN7 |
I'm wondering if I need to replace the pin part with a cotter pin of the right size with a couple washers on the sides?
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
The clevis pin had to have worked out of the hole to do that. I would have to look at an assembly to see which side is locked by the barrel tang (or whatever you want to call it).
EDIT: Now I remember...the barrel tang and pin are one piece....somehow it had to have backed out of the one side to pull on one side of the clevis. ??????? |
URY914 |
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 121,215 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None ![]() |
It may also have to do with how your pedal freeplay is adjusted and the "stop" on the pedal board. You may be over stressing the cable/clevis/cable tube in the back.
P |
DonTraver |
Senior Member ![]() ![]() ![]() Group: Members Posts: 829 Joined: 5-August 04 Member No.: 2,461 ![]() |
Had that happen on my 6, the hole in the pedal assy arm had elongated, cocking the pin in the hole. Welded up the hole and redrilled, problem gone. Good luck.
Don |
Porsche Rescue |
Saving and Enjoying Old Porsches ![]() ![]() ![]() ![]() Group: Members Posts: 2,978 Joined: 31-December 02 From: Bend, Oregon Member No.: 64 Region Association: None ![]() |
My money says Don got it right. Check the hole.
Cap'n Krusty |
There's supposed to be a bushing in the hole. The OE bushing is plastic, and lasts quite a while under normal use. Too much loading on the pin causes the described failure, and that comes from clutch wear and other geometry problems inside the bell housing. The tubes break loose for the same reason. The Cap'n |
GWN7 |
I didn't see a bushing while in there (hard to see anything while down there) , so that could be the problem.
boxstr |
MEMBER:PACIFIC NORTHWEST REGION ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,522 Joined: 25-December 02 From: OREGON Member No.: 12 Region Association: Pacific Northwest ![]() |
Bruce, Did you add the missing pedal board?
CCLINCLEVISANDBUTTHEAD |
GWN7 |
Yes, first thing I did once home.
I had a Engman one here, sitting looking pretty. Now it looks good in the car. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
Lo-Fi Version | Time is now: 20th June 2024 - 11:51 PM |
