Petepat |
Member ![]() ![]() Group: Members Posts: 60 Joined: 1-December 19 From: Florida Member No.: 23,691 Region Association: None ![]() |
So I have a 1/1/72 1.7L with a slightly sloppy shift (what's new) so I ordered some bushes and dismantled the shift only to find somebody had beaten me to it and it was fine. BUT putting it back with the right alignment is proving difficult, I can get some gears but not others, is there a tip on putting these things back with the correct alignment? Why did I touch it? I note in the Haynes manual I appear to have the later shift, the one with 2 springs which seems odd. Any tips gratefully received.
Shivers |
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,490 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California ![]() |
So I have a 1/1/72 1.7L with a slightly sloppy shift (what's new) so I ordered some bushes and dismantled the shift only to find somebody had beaten me to it and it was fine. BUT putting it back with the right alignment is proving difficult, I can get some gears but not others, is there a tip on putting these things back with the correct alignment? Why did I touch it? I note in the Haynes manual I appear to have the later shift, the one with 2 springs which seems odd. Any tips gratefully received. I’ll do my best, but first…What springs? Pic is worth, well you know. Originally mine was a 1972 1.7L Pics to come. |
Shivers |
![]() Ok, the adjustment is the bracket that holds the bushing for the shift rod, all the way at the tail. Where the bracket bolts to the trans, if those are loose you can move the shift rod end inside the cage it sits in. Up and down and side to side. That is the adjustment. To start, try to match what you see in the pic, this has 1 through 5. when adjusting have the bracket fasteners snug, so you can move the bracket with a bump, but it will not move on its own. |
Petepat |
Shivers |
Thanks for the photo, very useful. See my photo of gear shift (with 2 springs), I'm hoping not to have to get under the car as it was working OK before I took out the gear shift and it's more an issue of how to align it as I put it back. Any ideas? ![]() ![]() Ok, so your car is a 72. That shifter is stock, with two springs, not unusual. What is unusual is that shifter is out of a later 914 with a side shift. Can you give me a pic of your transmission where the shift rod controls the trans. Whether it is at the tail or on the drivers side of the trans. |
Shivers |
Shivers |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,116 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
Filthy. Clean the shifter assembly. Hard to tell…is the detent/1st reverse plate 180* out? As previously noted, post a picture of where the linkage enters the transmission. The differences between tail and side shift setups are well noted in the Haynes manual.
Petepat |
Petepat |
Petepat |
Petepat |
Petepat |
So its on the drivers side (see photo) so I guess it a side shifter, strange for a 1/1/72 model, does that mean it's been changed?
rhodyguy |
Side shift transmission conversion.
Petepat |
Do you have to change the whole of the gearbox for that?
Shivers |
Shivers |
rhodyguy |
Side, shift linkage enters on the driver side of the trans case. Tail, linkage operates a rod that enters the bottom of the back end of the trans. Photo Post #3. Entire linkage is dif for the SS. As is the dr side warm air guide. See if you can source a Haynes manual. The SS linkage uses 2 set screws. They are typically considered a one time use item. Beware when they back out on their own, near impossible to shift.
Spoke |
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,994 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None ![]() ![]() |
gereed75 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,263 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States ![]() ![]() |
There are MANY threads on here regarding shifter adjustment and methods. Here is my quickest answer. Part numbers are referenced to the typical side shift diagram found here http://www.914world.com/bbs2/index.php?showtopic=96903
1) All bushings have to be in good shape, one at firewall, one back aft at what I call the console 2)The two cone screws (26,23) have to be IN THEIR FACTORY DETENTS and tight 3) The bushings in the coupling (26) have to be good 4) There is one other bushing back in the shifter selector in the console under the black plastic cover (25). Access to this requires some disassembly. 50/50 chance it is good 5) If these are all good, then the easiest way I know to get it right is to take off the little access plate on the tunnel ahead of the firewall. This gets you access to the shift shaft (30). loosen the bolt (1) at the shifter coupling (19) through the access hole in the back of the shifter base (18). Put a set of needle nose channel locks on the shaft (30). Twisting the shaft in relation to the coupler (19) makes adjustments to the 1/R, 2/3, 4/5 planes. Adjusting the shift shaft (30) fore and aft relative to the coupler (19) makes adjustments in the fore aft planes 1/3/5 and R/2/4 planes. If you understand that, and take the time to understand how these fore aft and twisting motions operate the aft coupling (24) to shift the trans you can figure it out. the fore aft adjustment is pretty easy. The longitudinal adjustment is trickier and adjustments of one spline +/- make a difference. It will take some trial and error and thinking through it to get it right. I suggest that you remove the plastic cover (22) and see how the aft coupling (24) moves to select gears. Once you do that and understand it, Loosen bolt (1) and then you can manually move the aft coupler (24) to select a gear (I suggest 2 or 3), leave it in gear, and then put the cabin shifter (10) into the correct position against the spring shifter gate, re tighten the bolt (1) and see where you are, Make minor adjustments from there. Good luck. Remember, It was designed to be adjusted by a human being. |
Lo-Fi Version | Time is now: 26th June 2024 - 07:48 AM |
