FS: 1972 Red 914 new engine |
jim-c |
Oct 23 2023, 06:42 AM
Newbie Group: Members Posts: 20 Joined: 21-November 21 From: Fort Lauderdale Member No.: 26,090 Region Association: South East States |
Selling my 1972 914. Runs and drives great. Fort Lauderdale Fl. Lots of new parts and pieces. I'm moving very soon and need to downsize the vehicle collection.
Here's a particle list , more details in the folder link, if it works. My email is jcrtd@icloud.com I have pictures and video of every inch of car. https://www.icloud.com/iclouddrive/028cyzbH...DAkDng#914_info Work completed , new parts , etc. New engine 2258CC. : All new parts from European MotorWorks Engined assembled by European MotorWorks MegaSquirt Engine management. New floor pans installed by PO. Master cylinder , 914 rubber . Rebuilt brake calipers, all 4 corners . PMB Performance T-4 914 CASE DECK CASE T-1 / T-4 ALIGN BORE T-4 CASE DRILL TAP OIL GALLEY HOLES T-4/T-1 3/8" SOCKET PLUG ZINC 96MM CYL. ONLY 96MM PISTON 80MM STROKE 22MM PIN K/B 2.0H-BEAMRODSSETOF4 5.325" 22MM PIN 5/16" ROD BOLT ASSEMBLY LUBE MAIN BEARING SET .050 X STD X 1.00 THRUST T-4 2.0 ROD BRGS. STD T-4 STD CAM BRGS. T-4 E CAM 280 DUR. X .435" LIFT T-4 ALUMINUM CAM GEAR -3 CAM BOLTS T-4 SOLID LIFTER CHROMOLY CUT TO FIT PUSHROD 3/8" .035 WALL THICKNESS PUSHROD LENGTH MEASURING TOOL DIST. DRIVE GEAR BRASS TIMING GEAR LOCK RING CRANKSHAFT SPACER 914 215MM FLYWHEEL German not Chinese Heads: New European MotorWorks head castings. NEW BARE 2.0 HEAD INSTALL GUIDES PER HEAD INSTALL VALVE SEAT EACH SURFACE HEAD EACH 3 ANGLE VALVE JOB PER HEAD CUT HEADS DUAL SPRINGS EACH PORT & POLISH PR. 46MM T-4 VALVE Stainless Steal 38MM T-4 VALVE Stainless Steal 46MM INTAKE VALVE SEAT 38MM EXHAUST SEATS PORSCHE 2.0 8MM GUIDE STD DUAL SPRING H/D SET 8 CHROMOLY RETAINER SET 8 CNC HEAT- TREATED VALVE KEEPERS,SE MegaSquirt Engine Management: Parts from The Dub Shop MegaSquirt 3 computer Crank trigger wheel Coil pack New injectors Idle control valve Other items: New clutch, pressure plate and German flywheel. New tires. New fluid in rear end and transmission. Side shift transmission, works fine. Interior carpet. German loop from 914 rubber. New fuel line under gas tank. New fuel pump and regulator. Attached thumbnail(s) Attached image(s) |
Cairo94507 |
Oct 23 2023, 07:48 AM
Michael Group: Members Posts: 10,188 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
@jim-c Looks like a nice car; the rules require you post a price. GLWTS (IMG:style_emoticons/default/beerchug.gif)
jim-c |
Oct 23 2023, 02:48 PM
Oops , 21K is the price.
I’ll try and edit the original post. Thanks for the heads up . @jim-c Looks like a nice car; the rules require you post a price. GLWTS (IMG:style_emoticons/default/beerchug.gif) |
jim-c |
Oct 27 2023, 10:27 AM
The car is still available . Its going to be snowing soon.
Lo-Fi Version | Time is now: 27th January 2025 - 06:22 AM |
