Roll Bar Pad Revisted |
bkrantz |
Nov 24 2023, 07:35 AM
914 Guru Group: Members Posts: 8,175 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
What's the latest on replacement roll bar pads? This is one of the few parts I did not replace during my rebuild that is cracked and not looking good.
Does the 914 Rubber pad still require new latches? What about the Auto Atlanta repro? And anyone try their remanufactured pad? |
DRPHIL914 |
Nov 24 2023, 07:50 AM
Dr. Phil Group: Members Posts: 5,810 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
I installed a Auto Atlanta one when the first version of the 914rubber one had issues , i also have that but never installed it, probably have the revised latch covers too , and yes they redesigned their mold to correct the issue so now they fit properly and i believe they also have a more correct texture and pattern than the AA version but, unless you have to be a concours weenie, i didnt see a reason to swap them out. Mine looks great and no one has ever said anything during a show or otherwise.
Phil |
dr914@autoatlanta.com |
Nov 24 2023, 08:56 AM
914 Guru Group: Members Posts: 8,110 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
we have PLENTY on the shelf
What's the latest on replacement roll bar pads? This is one of the few parts I did not replace during my rebuild that is cracked and not looking good. Does the 914 Rubber pad still require new latches? What about the Auto Atlanta repro? And anyone try their remanufactured pad? |
Mikey914 |
Nov 24 2023, 12:57 PM
The rubber man Group: Members Posts: 12,741 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
What's the latest on replacement roll bar pads? This is one of the few parts I did not replace during my rebuild that is cracked and not looking good. Does the 914 Rubber pad still require new latches? What about the Auto Atlanta repro? And anyone try their remanufactured pad? When you say require new latches. Both require latches if you intend to attach a roof. If the question is does the 914Rubber one require new latch covers, it’s no. We are set up to use the stock latch covers. In stock on sale today. |
Lo-Fi Version | Time is now: 26th December 2024 - 10:16 AM |
