H2ohs |
Newbie ![]() Group: Members Posts: 15 Joined: 23-October 22 From: NH Member No.: 26,941 Region Association: North East States ![]() |
Hello, just ordered a replacement muffler for a 72 1.7 and it does not line up. New is about 1.75 wider compared to old (what is there) and does not line up with the flanges. I’m wondering if what is in my car is stock or not? It looks like my hanger has been cut too? Thoughts?
Attached thumbnail(s) ![]() |
Spoke |
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,994 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None ![]() ![]() |
Those look like 2.0 HE.
Dlee6205 |
Newbie ![]() Group: Members Posts: 46 Joined: 9-December 22 From: Burnsville, NC Member No.: 27,017 Region Association: South East States ![]() |
Yup, you have 2.0L heater exchangers so you need the matching muffler. |
H2ohs |
Ha. Ok- thanks everyone. We will get this thing straight eventually.
DC_neun_vierzehn |
Member ![]() ![]() Group: Members Posts: 418 Joined: 16-November 20 From: Delaware Shore Member No.: 24,893 Region Association: MidAtlantic Region ![]() ![]() |
From Bowlsby.net (ton of good info there)!
Attached image(s) ![]() |
rgalla9146 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,579 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None ![]() ![]() |
You have a 2 liter hangar too. |
H2ohs |
Awesome, thanks! Any advantage to the 2.0 over the 1.7/8?
wonkipop |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,439 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille ![]() ![]() |
Awesome, thanks! Any advantage to the 2.0 over the 1.7/8? original stock 2.0 muffler is very much like the design of the 911 muffler of the same period. internals probably more free flowing than VW muffler. stock 1.7 /1.8 muffler is a standard VW type 4 muffler more or less. there is a bit more to it when it comes to those but basically the later style muffler without the extra little tailpipe attenuator section is slightly more free flowing than the earlier ones. the earlier ones are straight off the VW 411 sedan and were designed for acoustic suppression (german TUV and USA noise level limits). the later single piece muffler is pretty much the VW bus muffler. its a tiny bit louder and a tiny bit less restricted believe it or not. but we are talking engines with 70-80 hp so don't think a 2.0 muffler on a 1.7 makes much of a difference to a 1.7 (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) also the 2.0 repro stock muffler available are generally more expensive than the 1.7/1.8 unit. at least when you compare the prices for the dansk unit. and the bus muffler is even cheaper than either of them and there is a trick to using one. they bolt straight on but will exit the wrong side. but there is a trick if you have a grinder and you can weld. |
majkos1 |
Member ![]() ![]() Group: Members Posts: 218 Joined: 11-August 17 From: Mile High 914 Member No.: 21,338 Region Association: Rocky Mountains ![]() |
weird engine bar, most definitely NOT original motor. someone put in 2.0? |
dr914@autoatlanta.com |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,912 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None ![]() |
the 2.0 setup is a good thing. The 2.0 factory repro muffler is the best to install for overall performance. Also need some transmission tail cover mounting cups they are missing. The engine bar is a later 72 variety. Also need a plastic rear shift cover and boot
914werke |
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,190 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest ![]() ![]() |
Umm... this was discussed prior. Depending on your choice of muffler you may have fitment issues.
While the prior comments are spot on, the 2.0L components were never installed/delivered combined with the early tail shift installed |
H2ohs |
weird engine bar, most definitely NOT original motor. someone put in 2.0? I’m just digging in to this thing. I ordered all the shift linkage fixings- that’s on the winter list too. Do I check the sn to determine the engine that’s in it? Now I’m a little worried.. and excited lol |
Ottomotion |
Newbie ![]() Group: Members Posts: 49 Joined: 12-January 23 From: Central California Member No.: 27,090 Region Association: None ![]() |
How about a quick pic of the intake bolts on the heads?
H2ohs |
Oh right, 3 vs 4 bolts. (Searching helps!). It’s got 4. Previous owner did have an extra 2.0 engine and maybe was using parts from it?
Lo-Fi Version | Time is now: 26th June 2024 - 02:45 AM |
