slammin |
Newbie ![]() Group: Members Posts: 2 Joined: 14-January 15 From: hudson valley ny Member No.: 18,325 Region Association: North East States ![]() |
hi Does any one know what size axels to use in my stuation I have a 914 with a 964/3.8 915 trans with a wave track course spline, flipped ring and pinion ,108mm trans flanges course splined 6 /10mm bolts and 911 stub axels also 108mm 6/10mm bolts . thanks for any info Slammin
mate914 |
Matt ![]() ![]() ![]() Group: Members Posts: 762 Joined: 27-February 09 From: Eagles mere, PA Member No.: 10,102 Region Association: North East States ![]() ![]() |
hi Does any one know what size axels to use in my stuation I have a 914 with a 964/3.8 915 trans with a wave track course spline, flipped ring and pinion ,108mm trans flanges course splined 6 /10mm bolts and 911 stub axels also 108mm 6/10mm bolts . thanks for any info Slammin Empi and Swayaway both make one in the size you need. Others on the board would know better than I. Hopefully they chime in. Matt (IMG:style_emoticons/default/flag.gif) |
Steve |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,622 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California ![]() ![]() |
hi Does any one know what size axels to use in my stuation I have a 914 with a 964/3.8 915 trans with a wave track course spline, flipped ring and pinion ,108mm trans flanges course splined 6 /10mm bolts and 911 stub axels also 108mm 6/10mm bolts . thanks for any info Slammin Empi and Swayaway both make one in the size you need. Others on the board would know better than I. Hopefully they chime in. Matt (IMG:style_emoticons/default/flag.gif) Sway-A-way axles part number 2420 20.25” custom 930 axles is what I used with my 108mm CV's and stub axles. PMB sells the sway-a-way axles and the lower cost empi version. https://pmbperformance.com/collections/pors...rear-axle-axles |
dr914@autoatlanta.com |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,912 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None ![]() |
I have 914 cv axles in my 3.0 with 915. fit perfectly with the smaller 914 sized output hubs
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,334 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
hi Does any one know what size axels to use in my stuation I have a 914 with a 964/3.8 915 trans with a wave track course spline, flipped ring and pinion ,108mm trans flanges course splined 6 /10mm bolts and 911 stub axels also 108mm 6/10mm bolts . thanks for any info Slammin Empi and Swayaway both make one in the size you need. Others on the board would know better than I. Hopefully they chime in. Matt (IMG:style_emoticons/default/flag.gif) Sway-A-way axles part number 2420 20.25” custom 930 axles is what I used with my 108mm CV's and stub axles. PMB sells the sway-a-way axles and the lower cost empi version. https://pmbperformance.com/collections/pors...rear-axle-axles Steve has it right. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 26th June 2024 - 06:23 AM |
