WTB bottom "oil pan tins" for 2.0 |
87m491 |
Dec 8 2023, 10:17 AM
Member Group: Members Posts: 295 Joined: 29-July 12 From: Portland, the original! Member No.: 14,731 Region Association: North East States |
Looking for the L&R tins that run over the heat exchangers to the oil pan for a 74 2.0.
(and good source for exhaust studs and proper nuts) thx Mike email is best (IMG:https://i.imgur.com/Iujfsw9.jpg) |
Jack Standz |
Dec 8 2023, 11:07 AM
Member Group: Members Posts: 369 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None |
technicalninja |
Dec 8 2023, 11:34 AM
Senior Member Group: Members Posts: 1,851 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
Thanks for the link! I need them as well and $60 each for repops works fine with me.
Saved me some time! |
rhodyguy |
Dec 8 2023, 12:44 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,188 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
On the DR side, the rear rod lives above the Warm Air Guide on a tail shifter. The one pictured has it below and is for a side shift trans. The pass side WAG is the same for either a side or a tail shifter. Curve on top for side, curve on bottom for tail.
87m491 |
Dec 8 2023, 01:15 PM
On the DR side, the rear rod lives above the Warm Air Guide on a tail shifter. The one pictured has it below and is for a side shift trans. The pass side WAG is the same for either a side or a tail shifter. Curve on top for side, curve on bottom for tail. But apparently different between 1.7/1.8/2.0 fitments? |
Jack Standz |
Dec 8 2023, 01:34 PM
87m491 |
Dec 11 2023, 07:02 AM
Yeah but AA seems to be all over the place with the descriptions. AFAIK they are different depending on engine size and side/tail shift set up. AA doesn't seem to differentiate and seem to infer they are all the same 1970-1974? (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-14731-1702299742.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-14731-1702299742.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-14731-1702299742.3.jpg) (IMG:style_emoticons/default/confused24.gif) |
FlacaProductions |
Dec 11 2023, 07:56 PM
Senior Member Group: Members Posts: 1,739 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
A couple of years back I wanted to replace my left air guide and AA had a sale. I ordered B022119356A LEFT AIR GUIDE PLATE 1973-74 914 - wasn't even close to fitting. I believe it was a repop. I found a good, used one on ebay and it fit perfectly.
Your mileage will vary. |
Lo-Fi Version | Time is now: 28th September 2024 - 04:52 PM |
