DC_neun_vierzehn |
Member ![]() ![]() Group: Members Posts: 408 Joined: 16-November 20 From: Delaware Shore Member No.: 24,893 Region Association: MidAtlantic Region ![]() ![]() |
I'm replacing the wiper switch on my '73. I bought a used wiper switch from @914Sixer . There's a loose piece in the bag and I cannot tell where it goes in the switch.
Does it just pop in somewhere or is it broken? ![]() ![]() ![]() |
DC_neun_vierzehn |
dr914@autoatlanta.com |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,903 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None ![]() |
yup must be in there to ground the switch and properly work the intermittent if so installed
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,694 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
Looks like your new switch is missing the long metal piece that makes contact with that short ground piece.
(IMG:style_emoticons/default/popcorn[1].gif) |
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,915 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
Switch is 6 pin, for electric pump. No lever for squirter.
SirAndy |
Switch is 6 pin, for electric pump. No lever for squirter. Still needs to switch power for the pump. You're missing the part that makes electrical contact with the ground tab, which has nothing to do with the pneumatic squirter. (IMG:style_emoticons/default/idea.gif) |
DC_neun_vierzehn |
Looks like your new switch is missing the long metal piece that makes contact with that short ground piece. (IMG:style_emoticons/default/popcorn[1].gif) So I'll need this piece (see pink arrow) for the switch to work as well? ![]() |
SirAndy |
Looks like your new switch is missing the long metal piece that makes contact with that short ground piece. (IMG:style_emoticons/default/popcorn[1].gif) So I'll need this piece (see pink arrow) for the switch to work as well? That's what i'm thinking. Do you have a multi-meter? You should be able to trace out your new switch. Who knows, maybe it has some different innards we can't see. (IMG:style_emoticons/default/idea.gif) |
Lo-Fi Version | Time is now: 20th June 2024 - 09:14 AM |
