jnaughton |
Newbie ![]() Group: Members Posts: 12 Joined: 30-May 05 From: pittsburgh PA Member No.: 4,166 ![]() |
This has probabply been covered before, but how to adjust window so it meets the seal ?
JN |
mihai914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 800 Joined: 2-March 05 From: Montreal, QC Member No.: 3,697 Region Association: None ![]() ![]() |
Is it a early 70-72 car or later because the doors were different.
If it's a later door, when you remove the panel, you will see on the window mechanism a 10mm bolt acting as a stopper for height and that you can play with. I think it,s covered in every reference manual such as the Haynes. If it's early, sorry I don't know, but someone will. |
jnaughton |
It is a '74
JN |
bd1308 |
Sir Post-a-lot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 ![]() |
it's the late door then...
take the door pocket off, pull the plastic off of the window handle, unscrew the screw, pull the crank, pull the pad (carefully--there are plastic tab thingies that could get pulled out of the board) and you'll see the 8mm (or 10mm) bolt upside down...actually i believe it's double nutted, you can't miss it... use the crank to lower and raise the window.... while you're in there, i did some lubing of the track and what-not with some lithium grease.... OH and check the plastic door cam... |
Lo-Fi Version | Time is now: 26th June 2024 - 01:39 AM |
