1974 914/6 Conversion, For Sale |
PeregrineA1 |
Apr 30 2024, 10:38 AM
Newbie Group: Members Posts: 1 Joined: 27-July 19 From: Orange County, CA Member No.: 23,328 Region Association: Southern California |
1974 Porsche 914/6 Conversion
Total mileage unknown ~10,000 miles on rebuilt 2.2 liter with 911 E cams , by Daniel Becker Aluminum fuel lines PMO carbs, jetted by Jeff at Aase Brothers 914/6 oil tank and cooler, stainless steel braided lines New fuel pump, flywheel, clutch, T/O bearing in 2017, ~3,000 miles ago Patrick Motorsports engine mounts GT Racing headers (no heat/defrost), ceramic coated Powdercoated engine tin Upgraded oil sump plate High torque starter Original 901 transmission, shifts typically, 1st gear synchro is lazy 911SC front suspension and brakes, powder-coated 914/6 rear suspension and brakes (e-brake functional), powder-coated All fresh bearings Elephant Racing bushings Turbo tie rods Alignment and ride height by Johnsons Alignment Comp 914 rear shox kit Koni shocks all around Chassis stiffening kit Rear trailing arms reinforced 16x7 Fuchs with BFG Comp2 205/50-16 all around Spare set of 15x7 cookie cutters New lug nuts Bare metal repaint (no pics, by prior owner) Rear fenders rolled to accommodate wheel and tire combo All rust removed and repaired New jack points both side No hell hole, battery in rear trunk All new rubber for 914rubber Original trim with some scuffs Minor headlight gap/alignment issue left front Top is wrapped in satin black, has minor blemishes New Hella Vision Plus headlights Backup light does not work Original interior carpet in very good condition Frunk carpet is good Trunk carpet is fair Momo steering wheel Original steering wheel Auto Atlanta seat reupholstry and dash No radio, has block off plate Odometer does not work Clock does not work Oil temp is not calibrated to 6 cylinder sender Voltmeter works Speedo works, reads 10 mph fast This car is very nice and a great driver. We have taken numerous 300-600 mile road trips and had a great time. Time for it to put a smile on someone else’s face. $40,000 or offer Will work with your transportation company. Attached thumbnail(s) |
slowrodent |
Apr 30 2024, 11:31 AM
Member Group: Members Posts: 125 Joined: 29-February 20 From: Tucson/Oro Valley Member No.: 23,981 Region Association: Southwest Region |
That appears to be a very nice, well-sorted car. Best of luck with the sale
Lo-Fi Version | Time is now: 20th June 2024 - 06:24 AM |
