Installing new Dansk gas tank - having issues |
DC_neun_vierzehn |
May 28 2024, 11:11 AM
Member Group: Members Posts: 437 Joined: 16-November 20 From: Delaware Shore Member No.: 24,893 Region Association: MidAtlantic Region |
I have a '73 2.0.
About a year and a half ago, when we pulled the motor and trans for sending out to the rebuilder, I did a lot of research on whether to try and restore my gas tank or buy a new aftermarket tank. The inside of my tank is grungy. Most of my research and most of the helpful folks here on 914 World guided my decision to a new Dansk tank. I called George to make sure I was ordering the Dansk tank, and all of the correct additional parts (sock, washers, replacement lines, clamps, etc.). Because I had read/heard so many stories of the original batch of 914 Dansk tanks not fitting, I also made sure to ask if I was getting a newer Dansk tank that would actually fit. The tank and parts arrived while I awaited the conclusion of the motor and trans rebuild. Now ... fast forward to last weekend, when I finally could dive in and swamp out the tanks. I used several old posts here on 914 World and Pelican to help me with the step by step remove and install process. Thus, I WAS ALREADY aware of the issue I would need to tackle of either shimmying the plastic bridge under the strap or removing some material from the top rib of the tank as detailed in THIS POST. However, one of my last steps before tackling that was to install the expansion tank and fuel filler on the new Dansk tank. That's where I ran into problems. If I install the fuel filler first, I cannot get the expansion tank on. if I install the expansion tank first, I cannot get the fuel filler on. They interfere with each other indicating that the mounts for the expansion tank are too far over on the passenger side (or the fuel filler hole in the tank is too far toward the driver side). Also, it looks like the fuel sending until it not resting in the indented section on the bottom of the expansion tank further preventing installation of it. Before calling Auto Atlanta, I wanted to check here to see if anybody else has run into this exact issue installing a new Dansk tank? Does it sound like I have sent an old non-fitting Dansk tank? Other thoughts/ideas/suggestion? |
DC_neun_vierzehn |
May 28 2024, 11:17 AM
Here's a pic of the fuel filler installed, but the expansion tank just resting unable to get into position to the mount on each side. The circled area is where the contact/interference is occurring.
Here's a pic to show the mount not matching up one the PS. Here's a pic to show the mount not matching up one the DS. |
rjames |
May 28 2024, 11:50 AM
I'm made of metal Group: Members Posts: 4,109 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Edited- thought I had found a thread with info other than the one you posted to, but it was for a different issue.
Any chance that your tank is for the later plastic expansion tanks? |
BillJ |
May 28 2024, 12:00 PM
Senior Member Group: Members Posts: 1,167 Joined: 4-March 13 From: charlotte, NC Member No.: 15,610 Region Association: None |
Maybe bend the inside bracket out to pull away from the overflow?
DC_neun_vierzehn |
May 28 2024, 01:10 PM
Maybe bend the inside bracket out to pull away from the overflow? That may work, but I'm doubtful based on how far they would need to move. I'd guess it's around an inch or so. And I'm not sure the sender top and plug would still line up with the indentation in the bottom of the expansion tank. And if this is the wrong tank and I need to ship it back, I don't want to modify it at all. |
BillJ |
May 28 2024, 01:24 PM
The tab difference is orientation if memory serves. It is rotated 90 degrees. So this is the right tank in theory
wonkipop |
May 28 2024, 06:58 PM
Advanced Member Group: Members Posts: 4,594 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
this might help? not sure.
does it have the tabs etc for the charcoal can or not? http://www.914world.com/bbs2/index.php?showtopic=370394 |
DC_neun_vierzehn |
May 29 2024, 07:24 AM
this might help? not sure. does it have the tabs etc for the charcoal can or not? http://www.914world.com/bbs2/index.php?showtopic=370394 Yes, it has all of the correct tabs, including those for the charcoal canister. The charcoal canister mounted fine. It's just the tabs for the expansion tank that appear to be off in their location. |
DC_neun_vierzehn |
May 29 2024, 07:30 AM
DC_neun_vierzehn |
May 29 2024, 07:54 AM
However, the measurements do not match re distance from the center of the filler hole to the drivers side tab for the expansion tank (which is the reason I cannot get the expansion tank of after bolting down the fuel filler piece). The driver side tab is 10 mm further toward the driver side as you can see in the pics below (old tank is approx. 27.5 mm and the new tank is approx. 26.5 mm).
OLD TANK: NEW TANK: |
BillC |
May 29 2024, 08:11 AM
Senior Member Group: Members Posts: 550 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region |
I think you found the problem -- the fuel filler hole seems to be in the wrong place.
Sounds like a call to AA is in order. |
wonkipop |
May 29 2024, 08:48 AM
I think you found the problem -- the fuel filler hole seems to be in the wrong place. Sounds like a call to AA is in order. yeah it is some kind of dansk screw up? like maybe they did a late tank filler location in an early tank. i mean even the "experts" did not seem to have their heads around what went down in the frenzy of 1974. (IMG:style_emoticons/default/biggrin.gif) 914s. mystery that could trip up anyone doing spare parts, (IMG:style_emoticons/default/blink.gif) |
BillJ |
May 29 2024, 10:37 AM
Bending isn't going to cover 10mm lol!!! Yeah you should call George.
dr914@autoatlanta.com |
May 29 2024, 10:59 AM
914 Guru Group: Members Posts: 8,043 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
do the brackets line up like your old tank? If not, maybe the bracket can be bumped over a bit? We have not run into the problem you are showing but HAVE run into the bracket being too tall on the inboard for the expansion tank
I have a '73 2.0. About a year and a half ago, when we pulled the motor and trans for sending out to the rebuilder, I did a lot of research on whether to try and restore my gas tank or buy a new aftermarket tank. The inside of my tank is grungy. Most of my research and most of the helpful folks here on 914 World guided my decision to a new Dansk tank. I called George to make sure I was ordering the Dansk tank, and all of the correct additional parts (sock, washers, replacement lines, clamps, etc.). Because I had read/heard so many stories of the original batch of 914 Dansk tanks not fitting, I also made sure to ask if I was getting a newer Dansk tank that would actually fit. The tank and parts arrived while I awaited the conclusion of the motor and trans rebuild. Now ... fast forward to last weekend, when I finally could dive in and swamp out the tanks. I used several old posts here on 914 World and Pelican to help me with the step by step remove and install process. Thus, I WAS ALREADY aware of the issue I would need to tackle of either shimmying the plastic bridge under the strap or removing some material from the top rib of the tank as detailed in THIS POST. However, one of my last steps before tackling that was to install the expansion tank and fuel filler on the new Dansk tank. That's where I ran into problems. If I install the fuel filler first, I cannot get the expansion tank on. if I install the expansion tank first, I cannot get the fuel filler on. They interfere with each other indicating that the mounts for the expansion tank are too far over on the passenger side (or the fuel filler hole in the tank is too far toward the driver side). Also, it looks like the fuel sending until it not resting in the indented section on the bottom of the expansion tank further preventing installation of it. Before calling Auto Atlanta, I wanted to check here to see if anybody else has run into this exact issue installing a new Dansk tank? Does it sound like I have sent an old non-fitting Dansk tank? Other thoughts/ideas/suggestion? |
DC_neun_vierzehn |
May 29 2024, 11:55 AM
Hi George. Thanks for chiming in and trying to help.
Yes, the expansion tank and fuel filler piece fit perfectly on the original tank. I'm not a welder, but even if I were, I could not move over the tabs for the expansion tank further to the DS, because as I mentioned earlier, the sender top and plug would then not line up with the indentation on the bottom of the expansion tank. All of this is adding up to the fuel filler hole in the tank is too far toward the DS. That seems to be throwing all of the geometry off for the expansion tank and fuel filler pieces. @dr914 @autoatlanta.com are you able to pull one of these Dansk tanks off of your shelves and try to mount a fuel filler and expansion tank to it to see if it fits? do the brackets line up like your old tank? If not, maybe the bracket can be bumped over a bit? We have not run into the problem you are showing but HAVE run into the bracket being too tall on the inboard for the expansion tank I have a '73 2.0. About a year and a half ago, when we pulled the motor and trans for sending out to the rebuilder, I did a lot of research on whether to try and restore my gas tank or buy a new aftermarket tank. The inside of my tank is grungy. Most of my research and most of the helpful folks here on 914 World guided my decision to a new Dansk tank. I called George to make sure I was ordering the Dansk tank, and all of the correct additional parts (sock, washers, replacement lines, clamps, etc.). Because I had read/heard so many stories of the original batch of 914 Dansk tanks not fitting, I also made sure to ask if I was getting a newer Dansk tank that would actually fit. The tank and parts arrived while I awaited the conclusion of the motor and trans rebuild. Now ... fast forward to last weekend, when I finally could dive in and swamp out the tanks. I used several old posts here on 914 World and Pelican to help me with the step by step remove and install process. Thus, I WAS ALREADY aware of the issue I would need to tackle of either shimmying the plastic bridge under the strap or removing some material from the top rib of the tank as detailed in THIS POST. However, one of my last steps before tackling that was to install the expansion tank and fuel filler on the new Dansk tank. That's where I ran into problems. If I install the fuel filler first, I cannot get the expansion tank on. if I install the expansion tank first, I cannot get the fuel filler on. They interfere with each other indicating that the mounts for the expansion tank are too far over on the passenger side (or the fuel filler hole in the tank is too far toward the driver side). Also, it looks like the fuel sending until it not resting in the indented section on the bottom of the expansion tank further preventing installation of it. Before calling Auto Atlanta, I wanted to check here to see if anybody else has run into this exact issue installing a new Dansk tank? Does it sound like I have sent an old non-fitting Dansk tank? Other thoughts/ideas/suggestion? |
DC_neun_vierzehn |
May 30 2024, 12:39 PM
Spoke with George on the phone today. He's going to reach out to Dansk for me tomorrow.
bkrantz |
May 30 2024, 07:59 PM
914 Guru Group: Members Posts: 8,042 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
How grungy is the inside of the old tank? That might be less significant than any rust-through or thin spots, typically from the outside in, and commonly where the stock felt pads held moisture against the tank. Maybe reconsider restoring your original tank?
DC_neun_vierzehn |
May 31 2024, 07:02 AM
How grungy is the inside of the old tank? That might be less significant than any rust-through or thin spots, typically from the outside in, and commonly where the stock felt pads held moisture against the tank. Maybe reconsider restoring your original tank? The original tank is rough inside. It looks like a PO tried to restore the inside with some sort of coating which is peeling and rust underneath. The gas I drained had noticeable floaters/debris. The fuel filter was pretty clogged. The tank is heading to the dump. |
76-914 |
May 31 2024, 07:25 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,608 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
How grungy is the inside of the old tank? That might be less significant than any rust-through or thin spots, typically from the outside in, and commonly where the stock felt pads held moisture against the tank. Maybe reconsider restoring your original tank? The original tank is rough inside. It looks like a PO tried to restore the inside with some sort of coating which is peeling and rust underneath. The gas I drained had noticeable floaters/debris. The fuel filter was pretty clogged. The tank is heading to the dump. FWIW, I just replaced my tank with a new one. I didn't have that option in 2014. After 10 years of housing modern day gasoline the liner dissolved and the resulting sludge resembled some Witches brew. This brew then took out my fuel pump & 2 in-line filters! Currently the old tank is in the back of my truck in the box that the new one came in. Just waiting for some opportunistic thief to lighten my load. (IMG:style_emoticons/default/happy11.gif) |
930cabman |
May 31 2024, 09:03 AM
Advanced Member Group: Members Posts: 3,511 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
How grungy is the inside of the old tank? That might be less significant than any rust-through or thin spots, typically from the outside in, and commonly where the stock felt pads held moisture against the tank. Maybe reconsider restoring your original tank? The original tank is rough inside. It looks like a PO tried to restore the inside with some sort of coating which is peeling and rust underneath. The gas I drained had noticeable floaters/debris. The fuel filter was pretty clogged. The tank is heading to the dump. The best place for it, attempting to resurrect an old crappy fuel tank is going nowhere I am sure George/Dansk will make it right |
Lo-Fi Version | Time is now: 16th September 2024 - 01:58 PM |
