Eric_Shea |
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,299 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains ![]() ![]() |
Wilwood Powerlite Rear Brake Kit for Porsche 914
Hey Teeners! PMB is proud to represent the entire line of Willwood products for all of our Porsche models but... look what we have here! An entire system designed for our awesome 914's. Most of our cars have a lot more power than they started with. To complement the added power, they need upgraded brakes and Wilwood Disc Brakes has come up with the perfect solution. You'll get forged aluminum Powerlite four piston calipers, brackets, and hubs, combined with larger, plain face or SRP drilled and slotted, "vented" rotors. That's right... finally vented rotors for your 914. Wilwood’s brake kit upgrade weighs ~53% less than our smaller OE cast iron, unvented brakes. Reduced unsprung rotating mass is always the right choice. Note: these brake kits MUST be used with a 914/6 or 911, 19mm master cylinder. Click Here for the Kit Brake kits feature:
Calipers: Powerlite (PL4R)
Rotors: Spec37 Plain or SRP Drilled & Slotted
Brake Pads: BP-10
Installation Parts:
technicalninja |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,474 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region ![]() ![]() |
Those are nice!
And ON SALE right now! 1500 OFF! Are those the calipers with the integral dust boots or the no-booted "Track" versions? Beautiful! |
zoomCat |
Member ![]() ![]() Group: Members Posts: 199 Joined: 13-August 04 From: Cincinnati, OH Member No.: 2,526 Region Association: None ![]() ![]() |
What size are the pistons?
I would assume you should really upgrade both front and back to maintain the correct braking proportioning. |
Eric_Shea |
Wilwood's radial mount calipers don't use dust boots. Many newer designs are (thankfully) forgoing the boot.
Here's a pic that shows the rear caliper and the pistons: ![]() Speaking of pistons, here's the rear specs... Piston 1 Bore (in): 1.00 Piston 2 Bore (in): 1.00 Piston Area (In²): 1.58 Piston Type: Stainless I would recommend you perform this modification as a "system". If that's not in the cards then I would begin with the "front" system only and then move to the rears. Putting this rear setup on your car without upgrading the front system is dangerous and not recommended. |
rgolia |
GeoJoe ![]() ![]() ![]() Group: Members Posts: 718 Joined: 5-February 10 From: PA Member No.: 11,329 Region Association: North East States ![]() ![]() |
Anyone install these yet?
eddie914 |
Newbie ![]() Group: Members Posts: 22 Joined: 8-February 24 From: Seattle Member No.: 27,926 Region Association: None ![]() |
Wow!
Is 289mm x 20mm kind of small. I could not keep 911SC brakes from boiling fluid after a couple of sessions at the track ... even with brake cooling ducts. Are larger front rotors available? Thanks, Eddie914 |
Cairo94507 |
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,267 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California ![]() ![]() |
Wow! Very nice kit for a decent price too. (IMG:style_emoticons/default/beerchug.gif)
davep |
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,254 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada ![]() ![]() |
Speaking of pistons, here's the rear specs... Piston 1 Bore (in): 1.00 Piston 2 Bore (in): 1.00 Piston Area (In²): 1.58 So this puts the Willwood between the 914/4 caliper with 33mm pistons and the 914/6 with 38mm pistons: 33mm 1.33sq in 2x1" 1.58sq in 38mm 1.76sq in increase the pistons to 1+1/16" to equal the 914/6 2x1.0625" 1.77sq in |
Lo-Fi Version | Time is now: 2nd April 2025 - 01:56 AM |
