914-6 PMS Engine Mount & Conversion Oil Tank, Patrick Motorsports New In Box Items |
Vysoc |
Jul 2 2024, 07:12 PM
Vysoc Group: Members Posts: 588 Joined: 27-August 09 From: Young Harris, Georgia Member No.: 10,737 Region Association: South East States |
Hello,
Up for sale will be two separate items: Item 1) Engine Carrier Mount - Porsche 914 Bulk Head to Porsche 6 Cylinder Engine Conversion. Utilizes Poly Urethane Bushings TIG Welded steel - Black Powder Coated Finish. 13.5 Lbs. Has option of welding in or bolting to existing chassis. $350.00 + Shipping - SOLD Item 2) 914-6 Conversion Oil Tank - Fits all Porsche 914-4 & 914-6 Chassis. PMS's Re-Production is a copy of the original 914-6 Steel Oil Tank. Made of .120/1/8" Aluminum and TIG Welded - The tank includes a 30mm or 16AN Feed and 26mm or 12 AN fittings. This tank is a direct replacement for the factory metal oil tanks that with age rust out from the inside. With this Aluminum Tank that problem is gone and the Aluminum Tank helps to cool the oil faster than the stock tank. Also included is the Oil Filler Neck Kit - Aluminum reproduction unit - for original or reproduction Porsche 914-6 Oil Tank - Includes Stainless Steel Oil Level Dip Stick. Yellow Zinc plated seal cap. High quality silicone hose with stainless steel clamps. Also included is the Oil Filter Console - Billet Aluminum Black Anodized, includes hardware & O-Ring, uses late style Mahle OC-54 Oil Filter. All three items for Oil Tank will be sold together. $750.00 + Shipping Please PM for any questions you may have about either of these items. Thank you, Vysoc |
Vysoc |
Jul 5 2024, 05:36 AM
Bump or Best Offer.
Vysoc |
Jul 9 2024, 05:10 PM
Bump......Price Reduction, these are both New In Box.
MikeV914 |
Jul 10 2024, 03:03 PM
I'm new here ... Group: Members Posts: 0 Joined: 19-May 22 From: Walnut Creek Member No.: 26,563 Region Association: Northern California |
Hello,
Sent you a PM on the engine mount Mike |
JOEPROPER |
Jul 10 2024, 03:08 PM
The answer is "no" unless you ask... Group: Members Posts: 1,191 Joined: 21-November 15 From: White Plains New York Member No.: 19,387 Region Association: North East States |
I'm interested in the mount also if the first guy passes
Vysoc |
Jul 10 2024, 07:15 PM
Vysoc |
Jul 10 2024, 07:17 PM
Vysoc |
Jul 11 2024, 05:15 PM
Engine Mount from Patrick Motorsports Sold!
Vysoc |
Vysoc |
Jul 18 2024, 06:10 AM
PMS Oil Tank/Filler Neck/Console - SOLD
Thank you, Vysoc |
Lo-Fi Version | Time is now: 25th October 2024 - 06:00 PM |
