mwizard1 |
Newbie ![]() Group: Members Posts: 22 Joined: 25-May 24 From: N San Diego Co Member No.: 28,148 Region Association: None ![]() |
I removed the top strap from the gas tank and it still will not come out. Is there an attachment under it?
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,924 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
No attachment below
Sometime they are stuck to the side pads from years /time Just pull harder 2 bodies can help |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,694 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
Vice grips on the seam helps. Just get one side up/loose then remove the rubber blocks one at a time should come up easily at that point. (IMG:style_emoticons/default/beerchug.gif)
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,804 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
Like the guys said, breaking the seal on the rubber pads will release the tank.
mwizard1 |
mepstein |
mwizard1 |
No attachment below Sometime they are stuck to the side pads from years /time Just pull harder 2 bodies can help No problem w/ the fuel line connections as they just pull off but I did need to remove the evaperative apperrastus off the top to get it passed the hood. Thanks for the help. |
GregAmy |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,468 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States ![]() ![]() |
Hey, pull the pads from the chassis and check for body rust underneath.
Same thing for on the tank where they lied. Tends to rust due to retention of moisture. |
Lo-Fi Version | Time is now: 2nd April 2025 - 02:25 AM |
