FastFroggy |
Member ![]() ![]() Group: Members Posts: 69 Joined: 27-November 15 From: South East MI Member No.: 19,415 Region Association: Upper MidWest ![]() |
Finally made it on track this weekend for a shakedown OTD at WaterfordHills. Car ran well, minus the shifter link issue I found. That said I was wondering if anyone has seen or made an adjustable rear sway bar set up. I have a front one, but have not found one for the rear.
Shivers |
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,939 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California ![]() |
Finally made it on track this weekend for a shakedown OTD at WaterfordHills. Car ran well, minus the shifter link issue I found. That said I was wondering if anyone has seen or made an adjustable rear sway bar set up. I have a front one, but have not found one for the rear. Weltmeister is what I have on back. It is adjustable. I've seen them for sale here used, I do not know if they are still selling them new |
914werke |
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,182 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest ![]() ![]() |
What do you have now? Any bar?
As mentioned Welt when it was available, was the go to. Unless you find one used or a NOS part Rose passion (who bought Automotion) stopped making them & now carries Tarret stuff. The Welt unit used a slider adjustment to tune the bar (tighter / looser) ![]() If you have a OE bar the only option is to use adjustable links, but the bulb attachment means custom hardware. I make a kit to use on the stock bar including modified shock bolts & custom links but it ended up kinda spendy. (IMG:style_emoticons/default/rolleyes.gif) ![]() |
FastFroggy |
Sweet!!! Thanks
Currently have a stock rear. I think a 17mm. Biggest problem for me are the end attachments. Even with new bushings, they are sloppy. Thanks again |
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,924 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
I run the adjustable Welt also. its a slightly bigger diameter than stock as I recall.
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,763 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
what size front bar do you have ??
ChrisFoley |
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,980 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None ![]() ![]() |
The Weltmeister rear bar on my race car is available to be sold.
Lo-Fi Version | Time is now: 2nd April 2025 - 02:24 AM |
