cozadrag |
Newbie ![]() Group: Members Posts: 1 Joined: 20-January 24 From: Atlanta Member No.: 27,863 Region Association: None ![]() |
My 19mm raised spindles also have raised brake line brackets that are crashing into the strut dust caps. Do the dust covers need to be shortened or just take off.. This is street legal but mostly a track and DE car. Thanks
Shivers |
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,939 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California ![]() |
technicalninja |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,474 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region ![]() ![]() |
Might not matter...
How low will the covers go installed on the car? If you have interference, you could shorten the dust cover a bit. Normally I try to leave weather protection devices on a street use vehicle. |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,804 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
So when you replace a steel trailing arm with an aluminum one on a LWB 911, you have to leave off the dust cap (cylinder) or it will hit the chassis. Unless the car is a daily driver, it’s not an issue. Might it wear out sooner than one with a dust cap, maybe but that’s not usually a concern on play cars.
Lo-Fi Version | Time is now: 2nd April 2025 - 02:24 AM |
