> Driver window adhesive, What glues glass to metal
theer
post Oct 3 2024, 07:49 PM
Question: what can I use to re-glue my door window to the metal channel. The old glue don’t glue no more. This is the metal c-channel on the front edge of the window glass that slides up & down in the vent window frame.
Thanks!
technicalninja
post Oct 3 2024, 08:27 PM
I want to know too!
The bottom channel came off of my right side window.
In my case it's the channel that the window regulator mounts too.
Rubber is in good shape, glue has died big time.
I'm leaning towards using Urethane window sealant. This is the stuff they BOND modern windows into cars today. It's a cross between caulk and epoxy.
I'm betting the drivers window is the same way.
https://www.amazon.com/3M-08609-Window-Weld...666399278682613
Sadly, I've never had a tube last more than a couple of days after being opened and I'll need a very small amount...
Check the tightness of both the front and the rear window (which are installed with butyl "cord").
https://www.pelicanparts.com/More_Info/N14R...8BoCHyYQAvD_BwE
My front window was OK, but my rear window was SO loose I'm glad I checked before driving car.
This was a tip I first saw here on this site.
It was a GOOD tip!
(IMG:style_emoticons/default/ninja.gif)
Front yard mechanic
post Oct 3 2024, 09:10 PM
I vote urethane.that stuff holds up even in the direct sunshine
Mikey914
post Oct 4 2024, 12:50 AM
The rubber man
I'd use epoxy if you are trying to glue the metal to the glass. Clean it up with a razor blade, then JB Weld it.
PS I have the new improved rollers if you are missing them
https://914rubber.com/window-track-roller-with-washer
87m491
post Oct 4 2024, 08:50 AM
If you want permanence, 3M 5200
QUOTE(theer @ Oct 3 2024, 05:49 PM) *
Thanks!
yeahmag
post Oct 4 2024, 10:26 AM
I've done this with windshield urethane, but I was off by just the smallest amount on the angle of the slider (1974 car). That gets amplified at the end of the window. I can't quite get the gaps right now... Just something to think about.
technicalninja
post Oct 4 2024, 12:30 PM
QUOTE(yeahmag @ Oct 4 2024, 11:26 AM) *
That's THE problem with urethane...
Once it "sets" you are SCREWED!
I've not been able to free a window installed with urethane without breaking the window yet!
I've got a good glass guy that can.
sbsix
post Oct 4 2024, 03:41 PM
only the lead dog enjoys a change in scenery...
I use Dow 995 White adhesive for bonding COE 90 glass to aluminum french cleats. Same adhesive they use for high rise building windows. I have no idea if it would work in this instance but I thought I’d bring it up.
porschetub
post Oct 4 2024, 08:51 PM
QUOTE(sbsix @ Oct 5 2024, 09:41 AM) *
Used the windscreen sealer and marked position of old sealer and then moved around with window up ,this would only work if winders aren't worn out and surround seals good and lined up properly ,top roof seal needs to be correct also ,not really a hard job ,cheers.
- Lo-Fi Version Time is now: 22nd December 2024 - 05:58 AM
