LED Gauge Bulbs on GEN light circuit |
nolift914 |
Oct 4 2024, 03:03 PM
Autoxer Group: Members Posts: 186 Joined: 24-May 09 From: Rockaway Beach NY Member No.: 10,399 Region Association: None |
Just wanted to say THANK YOU to all on 914WORLD this place is amazing.
I had an issue with my alternator not charging and the GEN light on. I had recently restored my dash gauges after reinstalling them and repairing some of the questionable wiring done by a PO. As always, I turned to 914WORLD for help! I read a thread on issues with GEN lights and realized my issue may not be the Alt after all, I had just installed NEW LED gauge bulbs. I switched the GEN light bulb back to the original Incandescent bulb and the ALT energized. problem solved. Using LED bulb on the GEN light circuit can cause issues with your charging system. |
930cabman |
Oct 4 2024, 04:23 PM
Advanced Member Group: Members Posts: 3,775 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
Just wanted to say THANK YOU to all on 914WORLD this place is amazing. I had an issue with my alternator not charging and the GEN light on. I had recently restored my dash gauges after reinstalling them and repairing some of the questionable wiring done by a PO. As always, I turned to 914WORLD for help! I read a thread on issues with GEN lights and realized my issue may not be the Alt after all, I had just installed NEW LED gauge bulbs. I switched the GEN light bulb back to the original Incandescent bulb and the ALT energized. problem solved. Using LED bulb on the GEN light circuit can cause issues with your charging system. Correct, AFAIK it is the wattage of the bulb. |
porschetub |
Oct 5 2024, 02:15 PM
Advanced Member Group: Members Posts: 4,750 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Just wanted to say THANK YOU to all on 914WORLD this place is amazing. I had an issue with my alternator not charging and the GEN light on. I had recently restored my dash gauges after reinstalling them and repairing some of the questionable wiring done by a PO. As always, I turned to 914WORLD for help! I read a thread on issues with GEN lights and realized my issue may not be the Alt after all, I had just installed NEW LED gauge bulbs. I switched the GEN light bulb back to the original Incandescent bulb and the ALT energized. problem solved. Using LED bulb on the GEN light circuit can cause issues with your charging system. Correct, AFAIK it is the wattage of the bulb. Think someone mentioned on here it was caused by the LED having a low current draw which isn't enough to "excite" the alternator ....could be wrong however ?. |
davep |
Oct 5 2024, 03:12 PM
914 Historian Group: Benefactors Posts: 5,220 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Well, yes, an LED draws in the 20mA range, so too low. BUT, an LED is a diode that passes current in only one direction and that is a BIG no no.
You must use the original incandescent bulb as the alternator light! |
bkrantz |
Oct 6 2024, 07:01 PM
914 Guru Group: Members Posts: 8,173 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
Well, yes, an LED draws in the 20mA range, so too low. BUT, an LED is a diode that passes current in only one direction and that is a BIG no no. You must use the original incandescent bulb as the alternator light! Correct. The gen light is the only non-LED bulb in my car. |
ClayPerrine |
Oct 7 2024, 08:43 AM
Life's been good to me so far..... Group: Admin Posts: 15,948 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
The gen light is the only non-LED bulb in my car. I can't say the same thing. I left the license plate lights as old incandescent bulbs. Makes it harder for the cops to read it. (IMG:style_emoticons/default/happy11.gif) |
emerygt350 |
Oct 7 2024, 02:37 PM
Advanced Member Group: Members Posts: 2,511 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
The gen light is the only non-LED bulb in my car. I can't say the same thing. I left the license plate lights as old incandescent bulbs. Makes it harder for the cops to read it. (IMG:style_emoticons/default/happy11.gif) Me too but just cause I was lazy. Everything but those, the gen and oil lights. I even got the rear trunk light I think. |
worn |
Oct 7 2024, 05:11 PM
can't remember Group: Members Posts: 3,372 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
Just wanted to say THANK YOU to all on 914WORLD this place is amazing. I had an issue with my alternator not charging and the GEN light on. I had recently restored my dash gauges after reinstalling them and repairing some of the questionable wiring done by a PO. As always, I turned to 914WORLD for help! I read a thread on issues with GEN lights and realized my issue may not be the Alt after all, I had just installed NEW LED gauge bulbs. I switched the GEN light bulb back to the original Incandescent bulb and the ALT energized. problem solved. Using LED bulb on the GEN light circuit can cause issues with your charging system. As I have in my notes you need a two watt bulb to bootstrap the alternator. |
worn |
Oct 7 2024, 05:12 PM
The gen light is the only non-LED bulb in my car. I can't say the same thing. I left the license plate lights as old incandescent bulbs. Makes it harder for the cops to read it. (IMG:style_emoticons/default/happy11.gif) Oh, but surely they know who you are led or not! |
bkrantz |
Oct 7 2024, 07:12 PM
The gen light is the only non-LED bulb in my car. I can't say the same thing. I left the license plate lights as old incandescent bulbs. Makes it harder for the cops to read it. (IMG:style_emoticons/default/happy11.gif) Just drive faster! |
emerygt350 |
Oct 8 2024, 06:39 AM
The gen light is the only non-LED bulb in my car. I can't say the same thing. I left the license plate lights as old incandescent bulbs. Makes it harder for the cops to read it. (IMG:style_emoticons/default/happy11.gif) Just drive faster! On my old Opel GT I could turn all the running lights off and keep the headlights on... |
Lo-Fi Version | Time is now: 22nd December 2024 - 05:32 AM |
