> Brake Lights, FIXED TODAY
jim_hoyland
post Oct 5 2024, 05:59 PM
Get that VIN ?
While working on an unrelated issue, I lost the brake lights.
Fuse on #9 is good, how does the brake pedal switch activate the stop lights ?
Need to know where to start……
jfort
post Oct 5 2024, 06:24 PM
We lost ours on the 914 race car. Switch at the brake pedal. Attached Image
jfort
post Oct 5 2024, 06:27 PM
jim_hoyland
post Oct 5 2024, 06:33 PM
Get that VIN ?
How is the switch wired, I’m looking to see where it goes
worn
post Oct 5 2024, 07:03 PM
can't remember
QUOTE(jim_hoyland @ Oct 5 2024, 05:33 PM) *
The switch is inside at the pedal cluster. It is normally open, with a lever that rides on the pushrod between the pedal and master. When you step on the pedal a spring closes the switch and current lights up the lights. As indicated, replacements are available and not too overengineered. As in kind of inexpensive.
bdstone914
post Oct 5 2024, 07:47 PM
bdstone914
@jim_hoyland
' post='3171371' date='Oct 5 2024, 05:33 PM']
[/quote]
They rarely fail.
Do you have power at fuse 9 ?
What wiring issue were you working on as it sound like it is related.
With ignition on, one of the wires at the switch should have power. I would first check for power at the brake light socket then the wire into the housing. I use a stick to depress and hold the pedal down if a helper is not available.
If all checks out there then move to the pedals.
jim_hoyland
post Oct 5 2024, 08:18 PM
Get that VIN ?
Power at Fuse 9
All the connections in the trunk are good.
The blue diode is not there any more
jim_hoyland
post Oct 6 2024, 02:14 PM
Get that VIN ?
A wire from the pedal cluster to the back of fuse 9 came loose. All fixed now
sixnotfour
post Oct 6 2024, 02:28 PM
- Lo-Fi Version Time is now: 22nd December 2024 - 05:34 AM
