Fuel sender readings ? |
jims914 |
Oct 29 2024, 05:55 PM
Member Group: Members Posts: 134 Joined: 11-March 11 From: Tempe,AZ Member No.: 12,816 Region Association: Southwest Region |
Anyone have any luck with a factory (porsche) dank, URO ?
There is a big difference in price ? I know they are a simple unit. Have had a new one and they still do not read very good ? |
FlacaProductions |
Oct 29 2024, 06:37 PM
Senior Member Group: Members Posts: 1,776 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
I just replaced my OEM one (wasn't going all the way to the top) with one from SMC (aftermarket) and now it jitters.
I did have to tighten up the pins as they were loose compared to the OEM but even with the tight pin/socket connection, it acts like a bad ground...I haven't had time to investigate further. Really annoying to take off the expansion chamber multiple times for something that should be a direct plug and play. |
jims914 |
Oct 29 2024, 07:56 PM
Mine on a full tank reads half full.
Its too bad there is not a way to correct the float to read correct going up or down ? Anyone have a fix ? |
Chris914n6 |
Oct 29 2024, 10:41 PM
Jackstands are my life. Group: Members Posts: 3,407 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
BTDT
Open it up and clean it |
930cabman |
Oct 30 2024, 04:55 AM
Advanced Member Group: Members Posts: 3,640 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
FlacaProductions |
Oct 30 2024, 08:50 AM
Yeah - I was going to replace mine and then open up the old one to see what's what - but I dropped it while taking it out - but maybe that's what it needs. I've had them apart on a different 914 years ago with success. They're just delicate inside.
VaccaRabite |
Oct 30 2024, 11:03 AM
En Garde! Group: Admin Posts: 13,584 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Mine reads about 3/4 full on a full tank of gas. I can get it to read 4/4 IF I fill the expansion tank too, which is not a great idea.
3/4 full it is. But my car will get to 1/4 full and stay there for close to 100 miles before the gauge reads lower. I just fill the tank whenever I go anywhere and treat the gas gauge as an educated guess. Zach |
worn |
Oct 30 2024, 06:00 PM
can't remember Group: Members Posts: 3,325 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
Mine reads about 3/4 full on a full tank of gas. I can get it to read 4/4 IF I fill the expansion tank too, which is not a great idea. 3/4 full it is. But my car will get to 1/4 full and stay there for close to 100 miles before the gauge reads lower. I just fill the tank whenever I go anywhere and treat the gas gauge as an educated guess. Zach When I made my triple gauge, I pulled the needle and put it back wrong. Out of gas when it said a quarter full. Fortunately the light still came on. Tried it again and went a bit too much in the wrong direction. I will get it right sooner or later. I have often wondered about putting a little potentiometer in line with gauges to set the baselines. Never tried it. |
fixer34 |
Oct 30 2024, 06:50 PM
Senior Member Group: Members Posts: 1,173 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest |
Use the gauge as an estimate and the warning light as a 'stop at next gas station'.
Spoke |
Oct 30 2024, 07:24 PM
Jerry Group: Members Posts: 7,079 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
I had luck cleaning the OEM sender. Carefully cleaned and 2000 grit sanded the wires and it works well now. I fill up when I get to 1/2 tank on my 914 and my 930.
bkrantz |
Oct 30 2024, 08:03 PM
914 Guru Group: Members Posts: 8,111 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
jims914 |
Oct 30 2024, 10:49 PM
Thanks guys for all the input will try the 2000 grit sanding to he wire.
Hate to have to order a factory one at $400.00 + |
Lo-Fi Version | Time is now: 1st November 2024 - 02:14 AM |
