'71 1.7 won't start, Increasingly difficult to start when cold now won't start at all |
boxster914 |
Nov 11 2024, 03:07 PM
Member Group: Members Posts: 77 Joined: 17-September 20 From: NC, USA Member No.: 24,700 Region Association: South East States |
Here is a video of my starting problem:
cold start video I'm guessing it's not getting fuel? Prior to this issue I would notice that when I would turn the ignition on (the notch prior to cranking the starter) when the oil and alternator lights would illuminate, something in the engine would turn on and I'd hear a hum. Now, it is completely silent. I relocated the fuel pump to the front a while ago. |
windforfun |
Nov 11 2024, 03:52 PM
Senior Member Group: Members Posts: 1,985 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
Blown fuse? Blown fuel pump? I had to replace my pump a few years ago.
(IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) |
emerygt350 |
Nov 11 2024, 04:17 PM
Advanced Member Group: Members Posts: 2,485 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
Put a fuel pressure gauge on it.
FlacaProductions |
Nov 11 2024, 04:54 PM
Senior Member Group: Members Posts: 1,809 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
Check the fuses on the relay board - drivers side of the engine compartment. There will be two "slots" - you're interested in the rear-most one - closest to the round relay. Also check "relay 3" by swapping with "relay 4" (assuming your heater fan works)
Edit: added diagram |
boxster914 |
Nov 13 2024, 04:52 PM
Thank you all for your replies. I look forwward to investigating this problem this weekend and will let you know how it turns out.
boxster914 |
Nov 16 2024, 04:58 PM
Brian- I swapped relay 3 and 4. It worked! Thank you.
Lo-Fi Version | Time is now: 28th November 2024 - 02:40 AM |
