Fuel Pressure Regulator |
StratPlayer |
Nov 13 2024, 08:20 PM
StratPlayer Group: Members Posts: 3,298 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
Going to slap one of these into my new motor, I saw where PMB was building a new 2258 and had one of these units installed on the motor.
https://thedubshop.com/universal-fuel-press...or-package-914/ |
bkrantz |
Nov 13 2024, 08:29 PM
914 Guru Group: Members Posts: 8,154 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
That's what I have in my system (from the Dub Shop). No complaints, so it must be working. (IMG:style_emoticons/default/biggrin.gif)
Actually, I do know that it reaches and holds required pressure, based on when I had a manual gauge plumbed into the engine fuel line loop. |
GregAmy |
Nov 13 2024, 08:31 PM
Advanced Member Group: Members Posts: 2,399 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
I use it on my Microsquirt-converted D-Jet. 3-bar solid with my standard D-Jet pump.
Also used it on my Microsquirt-converted Toyota MR2 race car. Solid there, too. |
jim_hoyland |
Nov 15 2024, 12:34 PM
Get that VIN ? Group: Members Posts: 9,527 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Going to slap one of these into my new motor, I saw where PMB was building a new 2258 and had one of these units installed on the motor. https://thedubshop.com/universal-fuel-press...or-package-914/ How did you mount it ? I’m |
StratPlayer |
Nov 15 2024, 04:22 PM
Going to slap one of these into my new motor, I saw where PMB was building a new 2258 and had one of these units installed on the motor. https://thedubshop.com/universal-fuel-press...or-package-914/ How did you mount it ? I’m It mounts where the old fuel pressure regulator goes install is easy. |
jim_hoyland |
Nov 15 2024, 07:21 PM
Can it adjust the fuels pressure ?
bkrantz |
Nov 15 2024, 08:17 PM
Here's how I mounted mine. First the Dub Shop bracket.
Attached thumbnail(s) |
bkrantz |
Nov 15 2024, 08:19 PM
And regulator.
GregAmy |
Nov 16 2024, 08:08 AM
How did you mount it ? It mounts where the old fuel pressure regulator goes install is easy. Ditto. I just screwed mine into that same flange using its fittings. Can it adjust the fuels pressure ? No, it's fixed at 3 bar. If you're tuning most EFIs at our level then that's a good baseline. Stock D-Jet fuel pressure is 28; 3 bar is 43.5 psi. You could account for that with a tunable MPS from Tangerine: https://tangerineracing.com/shop/ols/produc...t-mps-diaphragm Mario also offers a 4 bar: https://thedubshop.com/fuel-pressure-regulator-builder/ Being a standard Bosch regulator, you could possibly find alternatives. |
Lo-Fi Version | Time is now: 28th November 2024 - 02:37 AM |
