> Vapor Trapper, Fuel Vapor Trapper
Gearup
post Nov 19 2024, 06:40 PM
Curious if anyone has used a product like Vapor Trapper in their setups. I have quite a bit of smell coming from the vent line of my modified in tank pump assembly. I hear this product works well with classic cars and modified classics but was hoping for a cheaper solution. The Vapor Trapper with mounting brackets is $349. I’m tired of my garage smelling of gas as well as the passenger compartment.
Chris914n6
post Nov 19 2024, 07:41 PM
Jackstands are my life.
Pricey for a charcoal canister.
You can make one out of tupperware and fish filter charcoal if so inclined.
technicalninja
post Nov 19 2024, 08:43 PM
That's a SCAM at 350...
Nothing but a charcoal canister if that!
Find a 914 canister and affix it appropriately.
Some of them are openable and you can change the 'activated charcoal" out yourself.
A charcoal canister is a "sponge" for fuel vapors, and you dry the sponge with airflow through it.
Most of the time the vapor rich air from this canister is induced into the intake stream.
Most cars use a "purge valve" which allow flow during cruise (not idle or WOT). This is fed into the intake manifold past the throttle blade. This requires a check valve that can be vacuum operated or electronic in nature.
The late 914 set up used bleed air from the fan housing and merely fed it into the air filter housing. If the engine is running canister purge is occurring.
This IS the simplest canister purge I've ever encountered!
mb911
post Nov 20 2024, 05:59 AM
I need to do something this next year with mine
mxkinn01
post Nov 20 2024, 08:44 AM
I am lucky enough to have the plastic late canister. The end pops right off and I replaced the original charcoal with fresh from a fish tank supply. Problem solved. FYI I threw the old charcoal in the trash and it smelled for two weeks.
Mike
slowrodent
post Nov 20 2024, 08:47 AM
I made my own per these instructions... Not running yet, but I'm optimistic (IMG:style_emoticons/default/biggrin.gif)
https://classicbroncos.com/forums/threads/d...anister.322134/
Steve
post Nov 20 2024, 08:51 AM
QUOTE(mxkinn01 @ Nov 20 2024, 06:44 AM) *
Mike
Same here.. I mounted it in front of the battery on my six conversion. Only had to run one hose from the tank.
slowrodent
post Nov 20 2024, 08:56 AM
worn
post Nov 20 2024, 07:58 PM
can't remember
QUOTE(slowrodent @ Nov 20 2024, 07:56 AM) *
That wouldn’t be PVC pipe with charcoal in it?
slowrodent
post Nov 21 2024, 08:46 AM
As per the instructions (above)... it is indeed PVC with steel wool and charcoal.. (IMG:style_emoticons/default/smile.gif)
Root_Werks
post Nov 21 2024, 10:34 AM
Village Idiot
QUOTE(Steve @ Nov 20 2024, 06:51 AM) *
Mike
Same here, mines in the engine bay. If you can find one, get the plastic can and swap out the charcoal.
technicalninja
post Nov 21 2024, 10:53 AM
QUOTE(slowrodent @ Nov 20 2024, 08:56 AM) *
The Rodent has skills...
That looks every bit as "custom" as the original post.
It ALSO looks double the size.
Bigger IS better!
(at least where charcoal canisters are involved).
OP, I'd look at his route FIRST!
- Lo-Fi Version Time is now: 21st November 2024 - 07:06 PM
