Front fuel filter, Couldn’t we do better than burying the filter under the tank? |
worn |
Nov 25 2024, 06:33 PM
can't remember Group: Members Posts: 3,355 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
Getting closer and closer to the all new for 1976 2056 starting extravaganza. No fuel pressure cause I kinked a hose. Sure, I may not need 75’ of hose slack under the tank. Remedied that only to find fuel weeping from a new fuel filter. I am getting used to pulling the tank but it seems like a supposedly serviceable filter might be placed in a more prominent spot. Like above the tank, seen from the frunk. Or like maybe at the beginning of the fuel delivery loop in the engine bay. Or even where it used to be under the car. Why is stock the best possible world? Don’t get me wrong, I love stock.
jim_hoyland |
Nov 25 2024, 06:40 PM
Get that VIN ? Group: Members Posts: 9,532 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I moved the filter and pump into the front trunk . Added a ball valve to shut off fuel during filter changes. Also added a fuel pressure gauge and covered the entire assembly with a removable lexan cover.
Attached thumbnail(s) |
Ishley |
Nov 25 2024, 07:07 PM
Member Group: Members Posts: 167 Joined: 4-October 21 From: Clarendon Hills Il Member No.: 25,957 Region Association: Upper MidWest |
I moved my fuel pump to the 76 location. I left the fuel filter in the rear in the original 72 location below the battery. Many will say that the filter should be ahead of the fuel pump…but every BMW I’ve ever owned has the fuel pump in the tank and a filter down stream. I think most modern cars have it that way.
I thought on the late cars, you pull the pump out (in the frunk) and the filter is behind it in a fitting. You could reach it without disturbing the tank. |
hndyhrr |
Nov 25 2024, 08:19 PM
Senior Member Group: Members Posts: 586 Joined: 1-September 13 From: central point,oregon Member No.: 16,332 Region Association: Pacific Northwest |
I moved the fuel pump to under the tank and the filter is up under by the steering rack so I don't have to pull tank to change the filter. Pumpkin is a 70 1.7
bkrantz |
Nov 25 2024, 09:02 PM
914 Guru Group: Members Posts: 8,154 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
In theory, lots of excess line (hose) below the tank lets you extract and replace the filter via the 4" access hole, and then return the filter to a more protected environment. That's what I did when I moved my pump to the front. I suppose the filter could live by the steering rack, especially if carefully located and anchored in place. I don't like the idea of putting the filter (and pump) in the frunk, where leaking gas could pond and cause a REAL BIG disaster.
BTW, as most of us know, modern vehicles with pumps and "lifetime" filters that live in gas tanks are a b*tch to replace, sometimes requiring dropping the tank, so a 914 set up that way would not be that different. (When I changed the pump in my Suburban I decided to cut an access hole in the cabin floor under the middle row seat instead of dropping the tank.) |
technicalninja |
Nov 25 2024, 09:16 PM
Advanced Member Group: Members Posts: 2,014 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
The placement of the filter decides the level of filtration in my book.
Pre-pump the filter is lower filtration level VS post pump. Modern stuff has an in-tank "sock" that is ten times finer than the in-tank screen of a 914 and it replaces both the screen and the pre-pump filter. Post pump for fuel injection is either a very fine filter (1960s-2005ish) or in modern stuff COMPLETELY left off... More than 70% of cars built today have no secondary filter at all! These cars all have plastic gas tanks that don't corrode, and the fuels today are many times cleaner than the fuels of the past. Depending on tank condition I'd use both a pre and post filter on FI and a pre pump filter on carbs. The pre-pump filter should be changed twice as often as the post. Edit: On many late model trucks, it is possible to remove the bed mounting bolts on one side, loosen the other side up bigtime, and tilt the bed up to gain access. A bit like a Grand Piano! You can easily change a pump on a full tank of gas this way. |
Jamie |
Nov 25 2024, 09:24 PM
Senior Member Group: Members Posts: 1,074 Joined: 13-October 04 From: Georgetown,KY Member No.: 2,939 Region Association: South East States |
I moved the fuel pump to under the tank and the filter is up under by the steering rack so I don't have to pull tank to change the filter. Pumpkin is a 70 1.7 I moved the pump and filter to the front above the steering rack cover, easy access. The sock in the tank is a useless extra maintenance item easily damaged, so external filters under tank placed before and after the pump is a much better alternative for access. (IMG:style_emoticons/default/aktion035.gif) |
JamesM |
Nov 25 2024, 11:46 PM
Senior Member Group: Members Posts: 1,997 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
I moved my fuel pump to the 76 location. I left the fuel filter in the rear in the original 72 location below the battery. Many will say that the filter should be ahead of the fuel pump…but every BMW I’ve ever owned has the fuel pump in the tank and a filter down stream. I think most modern cars have it that way. I thought on the late cars, you pull the pump out (in the frunk) and the filter is behind it in a fitting. You could reach it without disturbing the tank. (IMG:style_emoticons/default/agree.gif) This In my opinion the best pump/filter arrangement for 914s. Front mounted late style Bosch 2 port pump with NO fuel filter between the tank and the pump, just an adaptor in place of the stock filter to adapt the line size from the tank outlet to the pump inlet. Then post pump use a 5/16(8mm) in 5/16(8mm) out high pressure, decent sized (lager than stock), small micron filter. Ideally do this using the late style front trunk fuel pump blister so you can have more or less a straight shot of fuel line from the tank outlet to the pump inlet, and then 180 the pressure side of the pump back to the tunnel line. No bends in the suction side of the line help keep it from collapsing. Fun fact, this is what the VW factory eventually wound up doing as well in the mid 80s on the Vanagons that started out using the exact same pump and filter as the 75/76 914s to help with cavitation and noisy pump issues. The type 4 and early WBX Vanagons through about 84 used the same setup as the late 914s. Around 85 they replaced the pre pump filter with a barbed adaptor and used a larger post pump filter. then in the final years they just made the outlet on the tank larger to eliminate the adaptor. Given the Vanagon tanks had no screen or pre filter I don't have any concerns that design of pump can handle it. I look at it as the way the factory would have evolved the 914 had it stayed in production. I do like keeping the filter out of the engine bay though just to have less fuel volume to potentially boil back there. |
Craigers17 |
Nov 26 2024, 04:21 AM
Senior Member Group: Members Posts: 806 Joined: 5-August 17 From: Rome, GA Member No.: 21,317 Region Association: South East States |
Many folks will hate this setup for various reasons, but I moved my setup to the frunk mainly for ease of changing the filter/pump. I realize it's not pretty / hidden, but it is very easy to access and now I can change the filter in just a few minutes with virtually zero fuel spillage. I know......paint job is in need of love.
slivel |
Nov 26 2024, 11:23 AM
Old car....... older driver Group: Members Posts: 515 Joined: 10-July 04 From: San Diego Member No.: 2,332 Region Association: Southern California |
I moved the filter and pump into the front trunk . Added a ball valve to shut off fuel during filter changes. Also added a fuel pressure gauge and covered the entire assembly with a removable lexan cover. I recommend replacing those worm drive hose clamps with FI rated clamps. Not so critical on the input side but it looks like a worm drive clamp on the output side. |
Geezer914 |
Nov 26 2024, 03:51 PM
Geezer914 Group: Members Posts: 1,771 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
Munted my pump and filter under the steering rack. All I have to do is drop the steering rack pan to change the filter or service the pump.
rjames |
Nov 26 2024, 03:58 PM
I'm made of metal Group: Members Posts: 4,145 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
I moved the filter and pump into the front trunk . Added a ball valve to shut off fuel during filter changes. Also added a fuel pressure gauge and covered the entire assembly with a removable lexan cover. @jim_hoyland , I can't tell from the picture. Is your pump mounted to the sheet metal, or just lying 'loose'? If loose, I'd recommend fastening it to the sheet metal using the late style clamp and rubber dampeners. |
rfinegan |
Nov 26 2024, 05:03 PM
Senior Member Group: Members Posts: 1,027 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region |
I have been thinking of using a 81 Lincoln 5.0 spin on fuel filter where the 73 fuel pump would go and keep the 75 pump and pre- filter under the tank. It has got a cover and all too. Would make nice transition from the tangerine lines to the engine bay lines. Looks like a smaller spin on oil filter.
Justinp71 |
Nov 26 2024, 05:33 PM
Senior Member Group: Members Posts: 1,605 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
I moved the filter and pump into the front trunk . Added a ball valve to shut off fuel during filter changes. Also added a fuel pressure gauge and covered the entire assembly with a removable lexan cover. I recommend replacing those worm drive hose clamps with FI rated clamps. Not so critical on the input side but it looks like a worm drive clamp on the output side. Good call, I was going to say the same thing. The wormdrive clamps get distorted and do not clamp evenly, only rated for lower pressure systems. Even more important in the engine bay, there was a member here that burned down his car from a ruptured fuel line in the engine bay. |
Justinp71 |
Nov 26 2024, 05:39 PM
Could you move the filter to the engine bay? In a diagram I got from Clewett for an EFI system they had the filter after the pump. The clearances are large in the pump I believe they can most likely handle small particles.
Lo-Fi Version | Time is now: 30th November 2024 - 09:53 PM |
