Valve adjusting screws from 1973 2.0, 8mm large contact area SOLD |
914ltd |
Dec 1 2024, 06:58 PM
Member Group: Members Posts: 243 Joined: 18-April 03 From: Peoria, IL Member No.: 581 Region Association: None |
The 1973 2.0 used an 8mm adjusting screw that almost never wore PN 039.109.451.
No longer available. The contact area to the valve was much larger than the other 8mm screws. I don't ever remember replacing these screws due to pitting and worn areas that the small contact 8mm screws and especially the 10mm adjusting screws failed with. These adjusting screws will also help prevent pitting and damage to the valve stems. Changing to the "wobble foot" 911 8mm valve screw requires grinding the rocker arm, respacing the rocker assembly and resetting the geometry to correctly install. These used adjusting screws will require 8mm rocker arms but will require only regular valve adjustments. Lock nuts are included, $100. Shipped SOLD, Thanks! Attached thumbnail(s) |
jim_hoyland |
Dec 1 2024, 08:07 PM
Get that VIN ? Group: Members Posts: 9,598 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
What size do the later ‘75 L-Jet motors use ?
914ltd |
Dec 2 2024, 07:19 AM
anderssj |
Dec 3 2024, 10:30 AM
Dog is my copilot... Group: Members Posts: 1,720 Joined: 28-January 03 From: VA Member No.: 207 Region Association: MidAtlantic Region |
Brad,
Thanks for posting this. Would engine GA005694 use these adjusting screws? If it doesn’t already have them, then I’m interested. Thanks! Steve A- |
anderssj |
Dec 3 2024, 10:46 AM
Brad, I’ll take them. PM sent.
Steve A- |
Lo-Fi Version | Time is now: 5th February 2025 - 02:39 AM |
