Bowden heater cable grommet |
Peaty |
Dec 4 2024, 10:25 PM
Newbie Group: Members Posts: 4 Joined: 18-March 22 From: CA Member No.: 26,406 Region Association: Southern California |
Does anyone have a trick to install the grommet that allows the three "Bowden cable" heater controls to pass through the interior bulk head to the heater control box located in the gas tank area?
bdstone914 |
Dec 4 2024, 11:14 PM
bdstone914 Group: Members Posts: 4,735 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Does anyone have a trick to install the grommet that allows the three "Bowden cable" heater controls to pass through the interior bulk head to the heater control box located in the gas tank area? Have not tried it on that particular gromett but lube the groove and edges of the gromett, warm it with a heat gun, wrap several rounds of waxed dental gloss in the gromett grove leaving the loose end on the side that the lip is being pulled thru. insert as much of the lip thru the hole. Tie a loop in the end of the dental floss and pull the lip of the gromett thru. pther technoque is use a smal diameter right angle pic the pull the lip thru the hole. |
914Sixer |
Dec 5 2024, 07:10 AM
914 Guru Group: Members Posts: 9,034 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Put it in some boiling water to make it pliable.
ClayPerrine |
Dec 5 2024, 07:37 AM
Life's been good to me so far..... Group: Admin Posts: 15,950 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Buy a nice, new, soft one from 914Rubber? They go in easy.
Peaty |
Dec 5 2024, 11:15 AM
Does anyone have a trick to install the grommet that allows the three "Bowden cable" heater controls to pass through the interior bulk head to the heater control box located in the gas tank area? Have not tried it on that particular gromett but lube the groove and edges of the gromett, warm it with a heat gun, wrap several rounds of waxed dental gloss in the gromett grove leaving the loose end on the side that the lip is being pulled thru. insert as much of the lip thru the hole. Tie a loop in the end of the dental floss and pull the lip of the gromett thru. pther technoque is use a smal diameter right angle pic the pull the lip thru the hole. Thanks for the input! I'll give it a try and report back. |
Peaty |
Dec 5 2024, 11:18 AM
Peaty |
Dec 5 2024, 11:21 AM
Lo-Fi Version | Time is now: 26th December 2024 - 08:19 PM |
