> 914World Classifieds Rules
> FS: New Stainless Steel Rear Alignment Shims, 1, 2, and 3mm Thick 96mm, Any three for $35, or 6 $60 with 6 new Schnoor washers
bdstone914
post Dec 17 2024, 09:04 PM
bdstone914
Warning : Adding shims reduces the number of engaged threads of the 10mm attaching bolts. The stock length of the 10mm bolts is 55mm. If you have a shim pack more than 5mm use new longer 10.9 grade 10 mm bolts. I recently shimmed a 914 to correct the excessive rear camber. One side had about 10mm in shims before adding 3mm more in shims. We had four threads of engagement of the trailing bolts after adding more shim pack. We changed to 70 mm bolts. The other side had a shorter shim pack and the 70mm bolts bottomed out on the non threaded portion of the bolt. 65mm bolts worked.
I had a new batch of stainless steel rear alignment shims in 1, 2, and 3mm thicknesses.
Standard shims are 2, 3, an 4mm thick.
This assortments easily allows for 1mm increments of adjustment.
Any three shims for $35 or 6 for $60 shipped-. each group will include 6 new Schnoor washers as they need to be replaced if the bolts are loosened.
@technicalninja
@FlacaProductions
@racer914
technicalninja
post Dec 17 2024, 09:11 PM
I'll take a set of 6.
PM sent.
FlacaProductions
post Dec 18 2024, 11:12 AM
I'll take a set of 6. Sending PM, Bruce.
racer914
post Dec 18 2024, 11:24 AM
I'll take 6, let me know how to pay.
sixaddict
post Dec 21 2024, 11:17 AM
Bruce or anyone…..that uses Bird board…
I am getting the following message….i get nervous about changing things with all the #cammers.
Anyone else seeing this.
See below
sixaddict
post Dec 21 2024, 11:19 AM
Sorry deleted repeat
bdstone914
post Dec 21 2024, 09:48 PM
bdstone914
QUOTE(sixaddict @ Dec 21 2024, 11:19 AM) *
@ @sirandy
bdstone914
post Dec 25 2024, 09:07 AM
bdstone914
FlacaProductions
post Dec 25 2024, 10:05 AM
QUOTE(bdstone914 @ Dec 17 2024, 07:04 PM) *
Good point -thanks for the reminder!
bdstone914
post Mar 28 2025, 08:18 AM
bdstone914
bump
- Lo-Fi Version Time is now: 3rd April 2025 - 11:19 AM
