> Shift rod balls, How do I get those installed
PaIsa
post Jan 11 2025, 03:22 PM
I got most of the material I ordered so I started to install some of the goodies.
We tried to get the shift rod balls on the shift rod just after the fire wall, without any success. I know someone said to heat them. I tried using boiling water, no success. I will try with heating the ball and freezing the steel part.
Any other suggestion. These balls are hard and tricky to get aligned straight.
Again open for any advice.
Thanks
r_towle
post Jan 11 2025, 08:55 PM
Custom Member
Post a pic
I have not needed to use heat or cold….so I’m lost on which ones you are fighting with.
bdstone914
post Jan 11 2025, 09:29 PM
bdstone914
Not clear as to what you are asking. Is this a tail shift or side shift? A picture will help.
r_towle
post Jan 11 2025, 10:14 PM
Custom Member
Maybe it’s a tail shifter?
The cup bushings pop onto the balls with a firm smack from a hammer.
If you are doing it with the motor in, maybe a pry bar or a reversed clamp to press it on.
They do fit
6 User(s) are reading this topic (5 Guests and 0 Anonymous Users)
1 Members: Steve
- Lo-Fi Version Time is now: 12th January 2025 - 08:53 AM
