> Cup Holder, Simple Option
jdamiano
post Jan 13 2025, 03:01 PM
Wife told me last weekend she needed a cup holder before she would ride with me again. I got the one below made for a chair but it was perfect for a 914.
https://www.amazon.com/dp/B0BTYMS7HT/ref=em...?th=1&psc=1
930cabman
post Jan 13 2025, 03:18 PM
lucky you, wife won't ride with me "too fffiinn stinky"
sb914
post Jan 13 2025, 03:34 PM
Surf Guru
Looks like it’s made for it .
ClayPerrine
post Jan 13 2025, 05:07 PM
QUOTE(930cabman @ Jan 13 2025, 03:18 PM) *
Could be worse... I have to ride "bitch". (IMG:style_emoticons/default/biggrin.gif)
(IMG:style_emoticons/default/driving-girl.gif) (IMG:style_emoticons/default/betty914.jpg)
Osnabruck914
post Jan 13 2025, 06:07 PM
Or you can do this -
Go to a pick & pull junkyard and find yourself a suitable cup holder, 90's cars are usually the best. Then procure a spare center console cushion (don't sacrifice your original!). Carve out a cylinder in the cushion for the holder to sit in flush as you can get it. Paint the cup holder to match your interior scheme. The holder I used also has a removable ash tray with a hinged lid that I use as a spare change holder, that just pops out when you want to use the cup holder portion.
Attached Image Attached ImageAttached Image
worn
post Jan 13 2025, 06:10 PM
QUOTE(Osnabruck914 @ Jan 13 2025, 04:07 PM) *
I did the same thing with a pair of ss cup holders purchased from a yachting supplier. I can think of 914 adds with horses and airplanes but cannot recall one with a yacht. Maybe 914s don’t float so well.
Geezer914
post Jan 14 2025, 07:08 AM
Geezer914
Here is mine.Attached Image
930cabman
post Jan 14 2025, 09:54 AM
how did we live before them?
(IMG:style_emoticons/default/happy11.gif)
East coaster
post Jan 14 2025, 10:11 AM
Mine actually is from a yacht (IMG:style_emoticons/default/smile.gif)
friethmiller
post Jan 14 2025, 10:15 AM
... and I was just perfecting the "one-hand on the coffee and steering wheel while shifting" technique. (IMG:style_emoticons/default/biggrin.gif) I need a cup holder bad!
Olympic 914
post Jan 14 2025, 10:26 AM
And another one.
Its just held down with Scotch strips. Like Velcro but stronger. So I can remove it and put the pad back in place ( But I haven't since installing it. )
mb911
post Jan 14 2025, 10:40 AM
QUOTE(930cabman @ Jan 13 2025, 01:18 PM) *
Same here
Cairo94507
post Jan 14 2025, 06:11 PM
Michael
Shower daily? (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/av-943.gif)
r_towle
post Jan 14 2025, 10:54 PM
Custom Member
An old cylinder sitting on the passenger floor works well.
There is also a bolt on rennline cup holder you can use
ClayPerrine
post Jan 15 2025, 06:59 AM
I bought one of the 911 cup holders that is designed to mount to the seat rail. Here is a picture of it:
Then I took out the 6x1.0 screw in the knee pad below the heater controls, and replaced it with a stud and a long coupler nut. I bolted the cup holder to the coupler nut. That way I could swing it out of the way when not in use, and it was easy to reach from the driver's seat. Even a large Wataburger cup would fit with no problems. But it won't hold a can or bottle because it has no bottom. There are others out there that are similar with bottoms to support cans.
After I put in the Cayman shifter, I moved the cupholder to the mount on the front of the shifter.
FlacaProductions
post Jan 15 2025, 09:35 AM
BELL CO51 Octopus Cup Holder, Multicolor, One Size - Amazon
I put it by my left knee by the e-brake handle. Second one for the passenger when/if needed.
Never moves. Never tips. Throw it in the trunk when not in use.
Superhawk996
post Jan 15 2025, 10:07 AM
Germans could never understand Merica’ and its fascination with cupholders. (IMG:style_emoticons/default/rolleyes.gif)
mxkinn01
post Jan 15 2025, 02:08 PM
In a pinch I've used this technique.
burton73
post Jan 15 2025, 02:50 PM
Senior member, and old dude
I personally like the idea If you need one for a trip. I like the fixes you guys are coming up with that you just put it on and take it off easily I'm liking it although I'm never going to go for a run that long but, maybe a little water to take pills but then I got to pee.
The ones with the stock astray slot is also a very clever way of doing it as nobody smokes anymore or should I say that very few of our people smoke anymore, sorry Jimmy and JD
Best Bob B
(IMG:style_emoticons/default/bye1.gif) (IMG:style_emoticons/default/bye1.gif)
ClayPerrine
post Jan 15 2025, 03:57 PM
QUOTE(burton73 @ Jan 15 2025, 02:50 PM) *
Best Bob B
The only thing smoking these days is the engine on a 914... due to the oil leaks. (IMG:style_emoticons/default/happy11.gif)
- Lo-Fi Version Time is now: 5th February 2025 - 08:46 AM
