> Dumb Question but what is this?, Looking under my 73/74 1.7L noticing oil
thecleanoutking
post Jan 13 2025, 10:21 PM
As I get to know and love this 914 I bought back in July. I was looking around underneath yesterday and noticed an oil drip around a part I don't really know what it is??
Sorry just not that familiar with these cars thought maybe some of you could tell me a bit about what I'm looking at and where oil might be coming from..
I think its either a transmission breather or some kind of external filter??
Before I remove that clamp and look at what's there thought I might ask here first..
The oil seems to be coming from above it..Attached Image
rjames
post Jan 13 2025, 10:57 PM
I'm made of metal
That’s just the cover for the shift console.
Hard to tell from that pick where the oil is coming from. Prob a mix of oil and tranny fluid.
Shivers
post Jan 14 2025, 03:30 AM
Shift console. Two places it may leak. Where the shift shaft goes through the console and where it attaches to the transmission.
dax1969
post Jan 14 2025, 04:41 AM
Good day,
Had a leak there as well. Replaced the shaft seal and the rubber ring. Take it apart and you will see.
note : a friend of mine had a leak coming from one of the studs. He took the stud out and re-installed with some sealer.
btw, the black crud is some kind of protection the factory applied to the transmission. It's some kind of tar that I painstakingly removed by chipping it away. I thought it was hardened grease but nope..
good luck
Dax
930cabman
post Jan 14 2025, 10:01 AM
assuming it's a minor leak, you might consider leaving it. keep your eye on the trans oil level.
It's not a huge job to repair if you decide to get it fixed.
fiacra
post Jan 14 2025, 07:14 PM
Person.Woman.Man.Camera.TV
Transaxle oil is pretty pungent and has a very distinct smell. Your nose can tell you whether or not this is from the transmission or the engine.
worn
post Jan 14 2025, 07:29 PM
QUOTE(fiacra @ Jan 14 2025, 05:14 PM) *
Hadn’t thought about that but you are absolutely right. Looks like a relatively small oil discharge compared to many that I have caused, er hmmm I mean have seen.
r_towle
post Jan 14 2025, 10:51 PM
Custom Member
Remove clamp from cover
Pull cover off (it does not come off, just turn it and empty it out
Clean it out
Put it back
Monitor it in 6 months
- Lo-Fi Version Time is now: 5th February 2025 - 09:51 AM
