jim_hoyland |
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,691 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California ![]() ![]() |
I just received this replacement turn signal switch and noticed it a little different; the original switch has two copper bat wings on the top. The replacement only has one.
1. Is this gonna be a problem ? 2. What are the copper bat wings for ? Attached thumbnail(s) ![]() |
FL000 |
Member ![]() ![]() Group: Members Posts: 448 Joined: 31-January 12 From: Lancaster, CA Member No.: 14,076 Region Association: Southern California ![]() ![]() |
Hey Jim,
Pretty sure the wing is for the horn. In theory should work with one if that is how it was made (not defective) but can’t say from experience. |
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,120 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
Even original SWF ones went to single tang in the late 1990's, so yours is correct.
dr914@autoatlanta.com |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,161 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None ![]() |
72-74 HAD TWO FINGERS, 75 76 AND 76-81 924 HAD ONE FINGER FOR THE HORN CONTACT. EVERYTHING HAS BEEN SUPERSEDED TO THE ONE FINGER
jim_hoyland |
I have the new aftermarket turnsignal switch installed and it’s working fine except for the signal cancelling mechanism doesn’t return the switch.
I have manually push the switch arm after making a turn. The steering wheel is properly aligned; I wonder if others had this problem |
barefoot |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,368 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States ![]() ![]() |
Mine won't self cancel unless I make a substantial turn of the wheel. Can't remember if the 70 model I had any yrs ago had that problem.
FlacaProductions |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,908 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California ![]() ![]() |
Make sure the 4 slot head screws that hold the switch inside the column aren't over tight. they're there to hold it in place - not hold it down. Also make sure they're evenly tight. One corner tighter than the other makes it crooked and it'll bind.
jim_hoyland |
Make sure the 4 slot head screws that hold the switch inside the column aren't over tight. they're there to hold it in place - not hold it down. Also make sure they're evenly tight. One corner tighter than the other makes it crooked and it'll bind. Tried that, no change; the switch is the Beatle replacement, looks the same except for the single horn contact. And, I can hear a click after completing a turn, but the switch lever won’t rerun ??? |
jim_hoyland |
Came across this post re the same issue: http://www.914world.com/bbs2/index.php?sho...=320581&hl=
@North Coast Jim |
Lo-Fi Version | Time is now: 29th April 2025 - 02:07 AM |
