transmission questions?, sounds and humming? |
mike914duck |
Jan 23 2025, 08:55 PM
Newbie Group: Members Posts: 23 Joined: 24-September 04 From: sealbch,ca Member No.: 2,825 |
sounds of the transmission humming or different sounds?
jim_hoyland |
Jan 23 2025, 09:09 PM
Get that VIN ? Group: Members Posts: 9,599 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Hi Mike,
Tell us which gears the sound is prevalent and whether it occurs when accelerating or all the time. IIRC, i went through a similar noise years ago…..can’t remember what caused it though |
mike914duck |
Jan 23 2025, 09:43 PM
Hi Mike, Tell us which gears the sound is prevalent and whether it occurs when accelerating or all the time. IIRC, i went through a similar noise years ago…..can’t remember what caused it though It gets a humming in 4th and 5th gear and is a constant tone it my guess, this is my first trans issue except for loosing 1st gear 10 years ago or so from the original trans? |
mike914duck |
Jan 23 2025, 09:45 PM
Hi Mike, Tell us which gears the sound is prevalent and whether it occurs when accelerating or all the time. IIRC, i went through a similar noise years ago…..can’t remember what caused it though It gets a humming in 4th and 5th gear and is a constant tone it my guess, this is my first trans issue except for loosing 1st gear 10 years ago or so from the original trans? IIRC what steps taken from your similar noise put in rebuildt? |
technicalninja |
Jan 23 2025, 10:00 PM
Advanced Member Group: Members Posts: 2,377 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
Swing car right and left changing the load on each side at steady state when noise present.
Accelerate and decelerate in a single gear allowing engine deceleration. (Changes load front to rear and changes power delivery direction through the transmission.) This is also done when noise is present. Does noise increase with speed? One of the two tests should alter the noise. Left to right points to wheel bearings and possible differential side bearings. Front to rear points to transmission internal. |
technicalninja |
Jan 23 2025, 10:18 PM
Another test is to get it up to speed where noise is loudest, depress clutch, shift to neutral.
Noise still present? Swing car L/R, depress brakes. Turn engine off only 1 click. ABSOLUTELY do not engage steering lock. That can be a WILD ride! This turns the car into a glider. Noise still present? Swing car left/right. You can restart car before stopping by ignition on, release the clutch slowly in proper gear. Yet another test. Determine RPM where noise is present. Hold that RPM in neutral stopped. Noise still present? engine related Something SHOULD vary the noise. No way any of us could diag with info you have provided so far... Need more/better detailed info. If I had to guess right now my money would be on a wheel bearing but I wouldn't make a monetary bet yet. All the above test I would complete in less than 30 seconds... Takes longer to type than DO! (IMG:style_emoticons/default/ninja.gif) |
rjames |
Jan 23 2025, 11:33 PM
I'm made of metal Group: Members Posts: 4,199 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Humming in 4th and 5th may be the intermediate plate bearing.
jim_hoyland |
Jan 24 2025, 07:32 AM
There some good ideas for you. I took my car to a big open parking lot to do some of the tests.
Do you remember whether the rear bearing had been replaced ? |
mike914duck |
Jan 24 2025, 10:18 AM
mlindner |
Jan 26 2025, 09:55 AM
Senior Member Group: Members Posts: 1,623 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
I had a rear CV go last spring...after replacing both the noise was still there. one wheel with loose wheel nuts. WTF. Best, Mark
jim_hoyland |
Jan 26 2025, 08:13 PM
Front yard mechanic |
Jan 27 2025, 08:27 AM
Senior Member Group: Members Posts: 1,260 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None |
Get a better radio
mlindner |
Jan 27 2025, 11:39 AM
rjames |
Jan 27 2025, 12:10 PM
Artfrombama |
Jan 27 2025, 01:21 PM
Member Group: Members Posts: 234 Joined: 21-January 24 From: Alabama Member No.: 27,870 Region Association: South East States |
Following~~~~
My car has a similar noise, more noticeable when the car is turning left. Wheel bearings seem smooth and tight. Noticeable under power and coasting. |
Shivers |
Jan 27 2025, 02:00 PM
Senior Member Group: Members Posts: 2,909 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
rjames |
Jan 27 2025, 04:50 PM
Following~~~~ My car has a similar noise, more noticeable when the car is turning left. Wheel bearings seem smooth and tight. Noticeable under power and coasting. If it happens whether or not your in gear, it's likely a bad wheel bearing. If you can't tell which end it's coming from, put someone in the passenger seat with the window down to discern if it's a front or rear bearing as it's likely on the right side. |
Lo-Fi Version | Time is now: 5th February 2025 - 08:56 AM |
