Brake line differences - support through strut |
echocanyons |
Feb 2 2025, 01:21 PM
Advanced Member Group: Benefactors Posts: 2,104 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California |
I’m swapping the struts/brakes from a 75 Carrera to a 75 914.
The hole that the rubber brake line at the strut end doesn’t seem to be large enough to support my existing rubber brake line. Also, there looks to be two different support clips. Could someone educate me to the difference and what I should be using to connect my brake lines to a 1975 strut. Attached thumbnail(s) |
bdstone914 |
Feb 2 2025, 02:31 PM
bdstone914 Group: Members Posts: 4,754 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
The hole size should be the same in both struts. the type of hardware needs to match the rubber line type. both should use the later U shaped clips.
914Sixer |
Feb 2 2025, 05:35 PM
914 Guru Group: Members Posts: 9,066 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
73-76 use this clip, It is thin, early cars and 914-6 use thick one
willieg |
Feb 3 2025, 03:48 PM
Member Group: Members Posts: 143 Joined: 13-August 18 From: Pleasant Hill Member No.: 22,389 Region Association: Northern California |
When I put some 911 brake parts on my 74 914, I found the hole on the strut to be too small. Some finetinkering with a dermal tool enlarged the hole. Probably not best way but it worked.
iankarr |
Feb 4 2025, 02:00 AM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,538 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Montreal914 |
Feb 4 2025, 09:23 AM
Senior Member Group: Members Posts: 1,772 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
^^^ This!
I contacted Eric Shea at PMB and he set me up with the correct lines for my conversion (3" strut in my case). |
Lo-Fi Version | Time is now: 5th February 2025 - 03:51 AM |
