ctc911ctc |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,055 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States ![]() ![]() |
All,
As we all are, I am a bit obsessed with these cars and see a few more of them on my horizon, I would like to purchase a set of fasteners for the future so I am not waiting on the more specialized vendors. I found myself measuring a 6mmx1.0 - 12mm long bolt and thought - someone has a list - or the holy grail - some vendor has a button I can push to order all of the correct fasteners? Any ideas or leads? CTC911CTC |
Detroit |
Member ![]() ![]() Group: Members Posts: 91 Joined: 28-December 16 From: Detroit metro area Member No.: 20,709 Region Association: Upper MidWest ![]() ![]() |
That seems like a daunting and really expensive task. These things came with good quality fasteners. I'd suggest that if you plan to rebuild/restore one in the future, just pull them all out, and drop them off at a plater. It'll cost you a hundred bucks give or take to do the entire car...
ctc911ctc |
Already went that route - locally anodizing is pretty expensive - I have about 1/2 of them picked already on BelMetric - will continue depending on the outcome of this ask.
Thank you Detroit! That seems like a daunting and really expensive task. These things came with good quality fasteners. I'd suggest that is you plan to rebuild/restore one in the future, just pull them all out, and drop them off at a plater. It'll cost you a hundred bucks give or take to do the entire car... |
gord |
Member ![]() ![]() Group: Members Posts: 78 Joined: 30-May 20 From: Toronto, Canada Member No.: 24,334 Region Association: Canada ![]() |
Here's the hardware list I put together a few years ago:
Detroit |
Damn, gord, that must've taken ages...
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,893 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
nice list.....
95 pages. seems like re-using hardware is the easy button. brant |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,785 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
I’ve wired wheeled a lot of the fasteners and sent them out. Call PMB. Their rates are much better than your local guy (true 6?). Bel metric is fine for the normal stuff but at least a small percentage of the hardware is special to Porsche and the large nuts and bolts are expensive. I’ve done a couple parts in the past.
Attached image(s) ![]() ![]() ![]() ![]() ![]() ![]() |
ctc911ctc |
When you finished the car did it smell new?
Love the level of hardware attention - even the headlight mounting system! Thank you, VERY IMPRESSIVE I’ve wired wheeled a lot of the fasteners and sent them out. Call PMB. Their rates are much better than your local guy (true 6?). Bel metric is fine for the normal stuff but at least a small percentage of the hardware is special to Porsche and the large nuts and bolts are expensive. I’ve done a couple parts in the past. |
ctc911ctc |
If you like data - and I love data - this is an amazing list
My Belmetric Order just got sweet - also I will contact PMB for the not generic stuff. Here's the hardware list I put together a few years ago: ![]() (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/first.gif) (IMG:style_emoticons/default/first.gif) (IMG:style_emoticons/default/first.gif) (IMG:style_emoticons/default/first.gif) |
windforfun |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,043 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None ![]() ![]() |
Where does the color come from? Also, German steel?
(IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) |
rgalla9146 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,721 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None ![]() ![]() |
Hey Cary The best way to clean up your engines appearance is to use only the original hardware and finishes. Porsche used certain suppliers who proudly marked their bolts with their company name or a letter identifier. You'll find this is true of all of the 6mm tin and bolt fasteners on your engine. The car is very original and undisturbed. Best plan is to keep it that way. You don't want to hear this but degreasing, wire wheeling and plating the hardware is an investment in the value of the car. If you are short on standard hardware I probably have correct bolts. Flat washers, wave washers ( by size) and split washers can be bought in bulk. Rory |
ctc911ctc |
Good to know, the 6mm 1.0, x 12m hex bolts for the engine tin are in pretty bad shape - if they are marked as original - can you let me know how I would tell? I can send the hardware to PMB to be replated or may do it myself.........simple process.
I am de-greasing everything - check out the next set of pictures (IMG:style_emoticons/default/biggrin.gif) Hey Cary The best way to clean up your engines appearance is to use only the original hardware and finishes. Porsche used certain suppliers who proudly marked their bolts with their company name or a letter identifier. You'll find this is true of all of the 6mm tin and bolt fasteners on your engine. The car is very original and undisturbed. Best plan is to keep it that way. You don't want to hear this but degreasing, wire wheeling and plating the hardware is an investment in the value of the car. If you are short on standard hardware I probably have correct bolts. Flat washers, wave washers ( by size) and split washers can be bought in bulk. Rory |
ctc911ctc |
bump
bkrantz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,282 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains ![]() ![]() |
I guess you could go through every page in the factory parts catalog. (IMG:style_emoticons/default/headbang.gif)
rgalla9146 |
Good to know, the 6mm 1.0, x 12m hex bolts for the engine tin are in pretty bad shape - if they are marked as original - can you let me know how I would tell? I can send the hardware to PMB to be replated or may do it myself.........simple process. I am de-greasing everything - check out the next set of pictures (IMG:style_emoticons/default/biggrin.gif) Hey Cary The best way to clean up your engines appearance is to use only the original hardware and finishes. Porsche used certain suppliers who proudly marked their bolts with their company name or a letter identifier. You'll find this is true of all of the 6mm tin and bolt fasteners on your engine. The car is very original and undisturbed. Best plan is to keep it that way. You don't want to hear this but degreasing, wire wheeling and plating the hardware is an investment in the value of the car. If you are short on standard hardware I probably have correct bolts. Flat washers, wave washers ( by size) and split washers can be bought in bulk. Rory Cary these are the two most commonly used fasteners on 916 6 / 911 tin If you are short on them let me know. The machine screw is KAMAX Attached thumbnail(s) ![]() ![]() |
gord |
Damn, gord, that must've taken ages... I deal with a lot of metadata in my job, so I had a few tools that made it much quicker than you might guess. The hard part was figuring out the incomplete or erroneous details in the PET diagrams… and some mysteries I’ve only partially solved. |
Lo-Fi Version | Time is now: 12th March 2025 - 09:29 AM |
