> 914World Classifieds Rules
> WTB: 914-6 engine shroud and ducting
thomasotten
post Mar 10 2025, 09:32 PM
I have determined that the shroud on my 914-6 core is incorrect. I need the shroud that has the long ducting to the oil cooler. Anyone have the proper shroud? I also need the right side ducting next to the fan. Thanks
Montreal914
post Mar 10 2025, 11:11 PM
@mb911 Ben should have the engine tin, if I understood correctly what you are looking for.
EDIT: Looks like I didn't get this right... Well if you also need the perimeter tin, Ben got you covered.
As for the triangular piece next to the fan, I am going through this miself. Will you have heat hexchangers or going with headers with no heat? That triangular piece would be different depending on this.
thomasotten
post Mar 11 2025, 04:00 AM
I have the surrounding tin. I just need the piece to the right of the fan, the stock piece, not a block off plate. Also, if someone has the correct 914-6 shroud.
sixaddict
post Mar 11 2025, 05:17 AM
Source available that makes new……my shroud was ok but I needed the light gray duct piece. He can do both …..
I think he goes by Series 9……
Nice product in my experience
I will check and advise if Series 9 isn’t correct.
sixaddict
post Mar 11 2025, 05:25 AM
I may have an extra one of these….if you need. There is also a plate and plastic duct that goes there. Plate is available new.
Others helped me get this right so I’m just paying it forward…..thanks to them.
sixaddict
post Mar 11 2025, 05:41 AM
Correction
Series 900
sixaddict
post Mar 11 2025, 05:48 AM
Hope this is what you are needing
thomasotten
post Mar 11 2025, 07:00 AM
Yes I need the whole assembly including plate and plastic duct
sixaddict
post Mar 11 2025, 08:17 AM
So I have #6 newly powder coated satin black
# 7 available new
#5 I do not have.
Suspect best to see if you can land the whole package.
Good luck
Sorry about trip on Series 900 shroud…..misunderstood your question.
gereed75
post Mar 11 2025, 10:45 AM
I may have a spare #5.
I am away from my stash and will not be home until mid April. If you can’t find one remind me then and I will search my stuff.
Also check withKarl Hens at Thouroughbred Motorsports up in Corey PA. He has A LOT of stuff!
mlindner
post Mar 11 2025, 12:59 PM
You can just buy an addition air scoop that runs from your shroud to the cooler. Just cut a hole and rivet on. I have pictures of mine somewhere, I'll look for them. Mark
mlindner
post Mar 11 2025, 01:05 PM
Found this one. The long black object from the cooler up to back of shroud. MarkAttached Image
MasterCylinder
post Mar 11 2025, 07:09 PM
I have these four parts. Was told it’s a 2.2T shroud so it should be the same as a 914-6.
thomasotten
post Mar 12 2025, 12:59 AM
Wow, for a newbie to the forum you have EXACTLY what I need!
QUOTE(MasterCylinder @ Mar 11 2025, 05:09 PM) *
- Lo-Fi Version Time is now: 12th March 2025 - 10:04 AM
