jmargush |
Member ![]() ![]() Group: Members Posts: 468 Joined: 8-June 04 From: Goshen, IN Member No.: 2,176 ![]() |
Has anyone experienced the mark on the fan being off from where actual TDC is ?
Last time I had the engine out I put a dowel in cylinder #1 and found TDC and the factory mark was approx. 3/8" tot he left of where I feel TDC on #1 was. I am going to recheck it and see if I made an error the last time I did it. |
barefoot |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,355 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States ![]() ![]() |
I've seen where the fan is displaced from intended position with partially sheared woodruff key.
930cabman |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,986 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States ![]() ![]() |
mjrrti |
High Desert Member ![]() ![]() Group: Members Posts: 51 Joined: 4-February 14 From: Apple Valley, Ca Member No.: 16,959 Region Association: Southern California ![]() |
Has anyone experienced the mark on the fan being off from where actual TDC is ? Last time I had the engine out I put a dowel in cylinder #1 and found TDC and the factory mark was approx. 3/8" tot he left of where I feel TDC on #1 was. I am going to recheck it and see if I made an error the last time I did it. There should be a groove on the flywheel that you can see in the little opening on the bell housing top and bottom that will get you dead on. I like to get it on TDC and use a center punch to mark the flywheel @ 180 from under the car also. That really helps for valve adjustment. |
GregAmy |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,466 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States ![]() ![]() |
I've seen where the fan is displaced from intended position with partially sheared woodruff key. Yuuuuup. http://www.914world.com/bbs2/index.php?sho...=367703&hl= |
jmargush |
I've seen where the fan is displaced from intended position with partially sheared woodruff key. after 1/2 century of DAPO's, anything goes the dowel method should get you close. are you adjusting valves? Checking timing and this lead to questioning the marks. there seems to be a bit of range around the TDC mark where both valves are still closed So I feel pretty good about the adjustment and leak down numbers have been good with the mark I made using the dowel to find TDC |
technicalninja |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,459 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region ![]() ![]() |
Depending on year/application the fans are marked differently...
My 75 1.8L is ONLY marked at 7-9? (red). (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) The 73 2.0L fan I replaced it with was marked at both TDC (white) and total timing (27-30? red). I made a second TDC mark 180 degrees from the original (black) to allow LD testing on the opposing cylinders. |
GregAmy |
930cabman |
very informative thread, thanks for finding this |
jmargush |
I just checked it with a dowel again.
What I think I am seeing is a bit of dwell at the top of the stroke. Dowel stops moving a bit before the factory mark on the fan. Once it moves past the factory mark the piston starts to travel downward again. Does this sound logical/possible? |
GregAmy |
I just checked it with a dowel again. You can't calculate TDC with a dowel; to do it correctly you need a dial gauge and a cam degree wheel. If you have a hard piston stop (another tool used for degreeing in cams) then you can rotate the engine until the piston taps the stop, mark the pulley (or read the degree wheel) then rotate the engine the other way until it taps the stop and mark the pulley (or read the degree wheel). The halfway point between those two marks is TDC. https://www.summitracing.com/parts/sum-900189 GA |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,194 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
Please don't use a chopstick........ (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/av-943.gif)
http://www.914world.com/bbs2/index.php?act...&and,broken |
emerygt350 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,712 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States ![]() |
Or just don't be an idiot. You guys all have an idea of precision on your ability to set your timing dead on while juggling a light and holding the throttle and turning a dizzy that probably isn't justified. There is so much variation in these engines that just getting in the ballpark and returning to a previous setting is all your looking for. 30 for me is probably not actually 30 etc... even with Bluetooth, you set it to what the engine wants, not some absolute number. No tech is going to put a motor on the Dyno and set the timing to some preconceived number and keep it there.
Don't use the starter and a chopstick is fine. 5th gear moves it nice and slow. |
bkrantz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,284 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains ![]() ![]() |
Has anyone experienced the mark on the fan being off from where actual TDC is ? Last time I had the engine out I put a dowel in cylinder #1 and found TDC and the factory mark was approx. 3/8" tot he left of where I feel TDC on #1 was. I am going to recheck it and see if I made an error the last time I did it. There should be a groove on the flywheel that you can see in the little opening on the bell housing top and bottom that will get you dead on. I like to get it on TDC and use a center punch to mark the flywheel @ 180 from under the car also. That really helps for valve adjustment. This, for sure. Set the flywheel at TDC and see where the fan is. |
JamesM |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,051 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region ![]() |
Or just don't be an idiot. You guys all have an idea of precision on your ability to set your timing dead on while juggling a light and holding the throttle and turning a dizzy that probably isn't justified. There is so much variation in these engines that just getting in the ballpark and returning to a previous setting is all your looking for. 30 for me is probably not actually 30 etc... even with Bluetooth, you set it to what the engine wants, not some absolute number. No tech is going to put a motor on the Dyno and set the timing to some preconceived number and keep it there. My timing holds like someone is shining a laser pointer on my fan. No dizzy twisting required, or even possible. (IMG:style_emoticons/default/biggrin.gif) ![]() |
emerygt350 |
That is a very pretty engine you got there.
Lo-Fi Version | Time is now: 19th March 2025 - 10:53 AM |
