IronHillRestorations |
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,812 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None ![]() ![]() |
I did a ground up build on a really nice chassis about 22 years ago. It changed hands twice ending up with jerhofer, who took it up several notches. It’ll be fun to watch and see what it hammers at.
Blue wide body 914 6 conversion Attached thumbnail(s) ![]() |
jhynesrockmtn |
Member ![]() ![]() Group: Members Posts: 437 Joined: 13-June 16 From: spokane wa Member No.: 20,100 Region Association: Pacific Northwest ![]() ![]() |
I did a ground up build on a really nice chassis about 22 years ago. It changed hands twice ending up with jerhofer, who took it up several notches. It’ll be fun to watch and see what it hammers at. Blue wide body 914 6 conversion I looked at that one briefly. Looks like an amazbuild. |
echocanyons |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,107 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California ![]() ![]() ![]() |
I am very interested in the drive by wire.
What foot pedal was used? Looks like a great build |
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,790 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
saladin |
Member ![]() ![]() Group: Members Posts: 54 Joined: 18-September 07 From: Mountain View, CA Member No.: 8,125 Region Association: Northern California ![]() ![]() |
I am very interested in the drive by wire. What foot pedal was used? Looks like a great build @echocanyons not sure what @jerhofer used for a pedal. I have been contemplating a drive by wire setup and so far I found:
Using a OEM 987/997 pedal appeals to me so thinking of using the top half of Rennline's 987/997 fully adjustable gas pedal (installed one on my 987.2 Cayman) and making a custom mounting bracket similar to the one TOP.Design produced. Hope this helps, Ken |
echocanyons |
Thanks for the info Ken!
Turbo Kraft also previously sold a drive by wire pedal. https://parts.turbokraft.com/collections/91...=32214124265530 The connection can attach to a Jenvey actuator or probably any similar standard type. It would be nice to have this over the cable driven version. Definitely requires an engine management system though. Anyone else go this route or have thoughts on a solution? |
Ron914 |
Member ![]() ![]() Group: Members Posts: 216 Joined: 19-April 22 From: Huntington Beach,Ca Member No.: 26,487 Region Association: Southern California ![]() ![]() |
I too received a notification for this car , I added it to watch list so I will have to take a look later tomorrow ,kind of cool that I now know more of the history of this car .It looked like a nice car ,I believe it was already up $30,914.
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,269 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
Thanks for the info Ken! Turbo Kraft also previously sold a drive by wire pedal. https://parts.turbokraft.com/collections/91...=32214124265530 The connection can attach to a Jenvey actuator or probably any similar standard type. It would be nice to have this over the cable driven version. Definitely requires an engine management system though. Anyone else go this route or have thoughts on a solution? I am going with drive by wire for the flat fan conversion. I am going to use a Nissan 350Z throttle pedal sensor. It will all be tied back into the MS3Pro for the ability to run traction control. So I can actually have a hope of driving it in the rain without roasting the tires. But I am definitely adding a button to turn off the traction control in the dry. ![]() I will take the roller off the arm, and add a Porsche ball stud. I will make a hole in the top of the tunnel behind the pedal box, and mount it there. I will use a rod to hook it to the stock throttle linkage. I will also add a throttle return spring between the pedal bellcrank and the chassis until I get the correct feel from the gas pedal. Then I will add one of these to run it... (IMG:http://www.914world.com/bbs2/uploads_offsite/shop.fullest.fi-1143-1743768550.1.png) And at the engine end, I am using a pair of BMW M3 throttle actuators, one for each cylinder bank. ![]() |
Ron914 |
Thanks for the info Ken! Turbo Kraft also previously sold a drive by wire pedal. https://parts.turbokraft.com/collections/91...=32214124265530 The connection can attach to a Jenvey actuator or probably any similar standard type. It would be nice to have this over the cable driven version. Definitely requires an engine management system though. Anyone else go this route or have thoughts on a solution? I am going with drive by wire for the flat fan conversion. I am going to use a Nissan 350Z throttle pedal sensor. It will all be tied back into the MS3Pro for the ability to run traction control. So I can actually have a hope of driving it in the rain without roasting the tires. But I am definitely adding a button to turn off the traction control in the dry. ![]() I will take the roller off the arm, and add a Porsche ball stud. I will make a hole in the top of the tunnel behind the pedal box, and mount it there. I will use a rod to hook it to the stock throttle linkage. I will also add a throttle return spring between the pedal bellcrank and the chassis until I get the correct feel from the gas pedal. Then I will add one of these to run it... (IMG:http://www.914world.com/bbs2/uploads_offsite/shop.fullest.fi-1143-1743768550.1.png) And at the engine end, I am using a pair of BMW M3 throttle actuators, one for each cylinder bank. ![]() Clay , This is also interesting and cool .I really would like a 914-6 one day if its ever in the cards one day . I enjoy the comments and cool stuff you post . |
ClayPerrine |
Thanks for the info Ken! Turbo Kraft also previously sold a drive by wire pedal. https://parts.turbokraft.com/collections/91...=32214124265530 The connection can attach to a Jenvey actuator or probably any similar standard type. It would be nice to have this over the cable driven version. Definitely requires an engine management system though. Anyone else go this route or have thoughts on a solution? I am going with drive by wire for the flat fan conversion. I am going to use a Nissan 350Z throttle pedal sensor. It will all be tied back into the MS3Pro for the ability to run traction control. So I can actually have a hope of driving it in the rain without roasting the tires. But I am definitely adding a button to turn off the traction control in the dry. ![]() I will take the roller off the arm, and add a Porsche ball stud. I will make a hole in the top of the tunnel behind the pedal box, and mount it there. I will use a rod to hook it to the stock throttle linkage. I will also add a throttle return spring between the pedal bellcrank and the chassis until I get the correct feel from the gas pedal. Then I will add one of these to run it... (IMG:http://www.914world.com/bbs2/uploads_offsite/shop.fullest.fi-1143-1743768550.1.png) And at the engine end, I am using a pair of BMW M3 throttle actuators, one for each cylinder bank. ![]() Clay , This is also interesting and cool .I really would like a 914-6 one day if its ever in the cards one day . I enjoy the comments and cool stuff you post . Well, my hope is to one day make the WCR. But y'all will have to have in SoCal for me to come. I am not making a trip to Oregon or Washington state. That is just a bit too far for me. WCR and the NE Gathering are the two major 914 events we have not attended. It's a bucket list thing. |
Ron914 |
Thanks for the info Ken! Turbo Kraft also previously sold a drive by wire pedal. https://parts.turbokraft.com/collections/91...=32214124265530 The connection can attach to a Jenvey actuator or probably any similar standard type. It would be nice to have this over the cable driven version. Definitely requires an engine management system though. Anyone else go this route or have thoughts on a solution? I am going with drive by wire for the flat fan conversion. I am going to use a Nissan 350Z throttle pedal sensor. It will all be tied back into the MS3Pro for the ability to run traction control. So I can actually have a hope of driving it in the rain without roasting the tires. But I am definitely adding a button to turn off the traction control in the dry. ![]() I will take the roller off the arm, and add a Porsche ball stud. I will make a hole in the top of the tunnel behind the pedal box, and mount it there. I will use a rod to hook it to the stock throttle linkage. I will also add a throttle return spring between the pedal bellcrank and the chassis until I get the correct feel from the gas pedal. Then I will add one of these to run it... (IMG:http://www.914world.com/bbs2/uploads_offsite/shop.fullest.fi-1143-1743768550.1.png) And at the engine end, I am using a pair of BMW M3 throttle actuators, one for each cylinder bank. ![]() Clay , This is also interesting and cool .I really would like a 914-6 one day if its ever in the cards one day . I enjoy the comments and cool stuff you post . Well, my hope is to one day make the WCR. But y'all will have to have in SoCal for me to come. I am not making a trip to Oregon or Washington state. That is just a bit too far for me. WCR and the NE Gathering are the two major 914 events we have not attended. It's a bucket list thing. Clay , WCR is in so.California this year. It's @Oscars place for meeting and they will be doing two drives ,I know one will be in the local San Beradino mountains I believe going up to Big Bear Lake, There are still a few details to workout but the date is set for June 26-29th Check the Garage forum I would screen shot it for you but the site is having that weird stuff its been doing lately ,either "server not found" or taking a long time to open something . |
Ron914 |
Ron914 |
ClayPerrine |
Yea.. that's great. It won't happen this year. I have to get my car back up and running first. And that won't happen before this event.
Plus, I have to have enough vacation time. I just started a new job in January, so I don't have that next. |
Ron914 |
Yea.. that's great. It won't happen this year. I have to get my car back up and running first. And that won't happen before this event. Plus, I have to have enough vacation time. I just started a new job in January, so I don't have that next. Well maybe next year . |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,146 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
Here's a thread that Jer posted on Pelican following his part of the build:
http://forums.pelicanparts.com/porsche-914...74-914-6-a.html --DD |
Ron914 |
Here's a thread that Jer posted on Pelican following his part of the build: http://forums.pelicanparts.com/porsche-914...74-914-6-a.html --DD Dave , Somehow your comments ended up on two different posts . I also saw it on the WCR post |
Ron914 |
Here's a thread that Jer posted on Pelican following his part of the build: http://forums.pelicanparts.com/porsche-914...74-914-6-a.html --DD Dave , @Dave Darling Somehow your comments ended up on two different posts . I also saw it on the WCR post Not sure how that happened |
Ron914 |
My bad , I figured it out .
Dave_Darling |
Weird. I wonder if I replied in the wrong window, then corrected it somehow?
--DD |
Lo-Fi Version | Time is now: 19th April 2025 - 01:27 AM |
