Hammy |
mr. Wonderful ![]() ![]() ![]() Group: Members Posts: 1,826 Joined: 20-October 04 From: Columbia, California Member No.: 2,978 Region Association: Northern California ![]() |
I'm going (IMG:http://www.914world.com/bbs2/html/emoticons/screwy.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif)
Alright, so say I were to get a Raby 2056 kit, and put 40 or 44mm Webers on it... So then, what do I do about exhaust? I'm new to all this, so I don't understand the different types of exhaust. Headers? heat exchangers? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) So What would work well for a 2056? I need something inexpensive And for the heads. It says it comes with "Complete Super Stock remanufactured heads. 42x 36 valves oval exhaust ports, 96mm bore" , with the option to upgrade the heads to PORTED heads. Ok, so what's ported? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) And for the ignition. I don't know where to even start on this. I assume whatever ignition setup I have now isn't going to work. TIA. I'm trying to learn. |
LvSteveH |
I put the Poor in Porsche ![]() ![]() ![]() Group: Members Posts: 1,080 Joined: 22-April 03 From: Las Vegas, Nevada Member No.: 600 ![]() |
I would think weber 40's and SSI heat exchangers would work very well with Jake's setup and give you a very livable setup on the street that allows you to keep your heat. Upgrading the distributor to the mallory would probably be worth while considering the cost of the engine.
I'm sure others will chime in with other opinions and advice. It really isn't that much more expensive to step up to the 2270 and 44 webers, and you'll have a serious motor that others will envy. |
qa1142 |
Whiplash ![]() ![]() ![]() Group: Members Posts: 1,514 Joined: 1-June 04 From: Lake Zurich, Illinois Member No.: 2,140 ![]() |
Order the motor, talk with Jake, get your carbs and Distributor from him too. He'll get you hooked up. Price is good when you buy it all together too.
Hammy |
Initially I had hoped for a 2270, but with that I'd need a tangerine exhaust setup which is $1000+ . So the kit and just the exhaust would already have me well over 5k (IMG:http://www.914world.com/bbs2/html/emoticons/ph34r.gif) We're trying to keep it around 4.
Ok, so SSI heat exchangers. Whats SSI stand for? price range.. ? whats the diff. between HE's and headers? (IMG:http://www.914world.com/bbs2/html/emoticons/blink.gif) |
LvSteveH |
SSI's are a factory style stainless steel heat exchanger, they typically run from $150-300 per set.
Heat exchangers are basically headers with the provision to run factory heat. Of course a racing style header will offer a bit more performance, but on a street driven 2056, I'd take heat and a much lower cost all day over 5 extra horsepower. |
Hammy |
I definitely want heat. so does the heater fan thing in the engine compartment just blow air over the heat exchangers? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
Jake Raby |
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States ![]() |
Hammy,
Things like this is the entire reason people buy from me.. For support and a project that can be accomplished with zero trial and error and guesswork. The base engine the kit is derived from performed best with 44mm Webers with 32mm Venturis, 135 main jets, 200 air jets and 28degrees full advance and 12 degrees initial with a grey/grey curve. 40 webers can be used, with 34mm venturis but throttle response was lower and midrange power was as much as 5% lower, and efficiency dropped off. As for exhaust, a set of S/S heater boxes and a Bursch will work fine for the kit- this is no super tuned engine, although it will make 125 HP easily. Basically anything BUT the stock exhaust will work OK with this kit. As for the heads- Opt for the new castings with the port work, the efficiency of the engine is much better with them and the price is very favorable for a brand new pair of heads. remember: I'm the guy that can help you and the guy you are paying to do so.. Lean on me, not the guys here on the board for making these decisions! Here are a couple of power graphs from the 2056 base engines the kit was based from. The first one is with standard non ported heads and the second is with ported heads- note the differences across the board DO NOT LOOK AT ONLY PEAK HORSEPOWER!! You won't be using that unless you are constantly above 5252 RPM! Non ported combo (IMG:http://www.aircooledtechnology.com/type4/914/2056_daily.jpg) Ported combo (IMG:http://www.aircooledtechnology.com/type4/914/2056_daily_plus.jpg) The only difference between the two is a cam swap and the head swap.. Reliability, longevity and drivability are not compromised with the higher performance engine.. This is the same comboi that I just drove 1800+ miles with in my 912E and didn't even open the decklid to check the oil! I have been doing that with this engine for 86K miles, and only in 3 years! |
Twystd1 |
You don't want to know... really..... ![]() ![]() ![]() ![]() Group: Members Posts: 2,514 Joined: 12-September 04 From: Newport Beach, California Member No.: 2,743 ![]() |
Hi Hammy,
I was remembering what we talked about on the phone. So I have few questions for you. The answers will help us all help you!! What is the end result of this car? a) Toy to have fun in and race an occasional AutoX? (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif) Daily driver with great gas mileage? c) Daily driver with lots of horsepower and OK - bad gas mileage? (like 13-18 MPG.) d) Full blown ricer killer? e) Do you want it to handle like a good stock 914? f) Do you want it to handle like a very crisp street car? g) Do you want it to handle like a like a F16 fighter on steroids? h) Cosmetically, do you want it perfect or just pretty good or you don't care? I) Do you need heat on your car? Lots a guys in Kali run with no heat. Therefore no heat Xchangers. Just headers and good muffler. J) How much money are you setting aside for this build? K) What are you starting with? Is this a rust bucket or a perfect car or where in between? L) How much time to you have to devote to this project? I suggest you ask some knowledgeable members here on the forum to come over and look at what you have. I always have another member look at my stuff for a second opinion before I start my projects (thanks Skline, Aaron, John and the guys at the cofffee shop). The other way to do it is to simply trust Jake on the engine. (I would) And blindly go forward with what you can afford like most of us. Time has no meaning in the 914 world. Utter than that. I am here to help. Like I told ya on the phone. I don't know shit. Thats why I ask questions and READ READ READ until I think i understand my next course of action ... Keep asking dude.. By the way... How old are you? Cause I sniff you are young and pretty dam smart... Twystd1 |
Hammy |
Jake- thanks for the graphs and the info. And for the heads, as I'm trying to keep prices as low as I can, will the upgrade optional USED ported heads be a good choice? And yes I'm definitely leaning on you! I'm just trying to understand the basics. What about service in those 86k miles? Is it any more service required than say a stock engine? Clayton- Lots of questions! My end result for the car is probably a lot different than others. It'll be a daily driver, the car I drive to school once a week (home study), a RAIN car-I plan on weather-proofing the car as much as I can, the car I drive out on country twisty roads.. You know, that stuff. Maybe later in the future autocross, if I get the balls. And of course I'd love to show off the torque and outrun a few ricers once in a while, who wouldn't? I want it to handle well, as well as it should stock-wise with a front swaybar later on. I'm not looking to have the best handling teener out there. Cosmetically, well that's the least of my worries right now. My car has a badly dented up front bumper, different colored bumpers, small dings everywhere and a nice dent, desperate need of a repaint, ugly westerner wheels. (IMG:http://www.914world.com/bbs2/html/emoticons/wub.gif) I need heat! (IMG:http://www.914world.com/bbs2/html/emoticons/pray.gif) The car is overall probably a C. Maybe a parts car to some down in LA. Driver's floor pan under seat needs replacing, bottom rear trunk too. Hell hole doesn't really seem that bad. Small hole in the engine shelf part. Who knows what i'll find when the engine is out. Longs seem real good too. Interior could be better. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) trying to keep it around 4k for parts and everything, though I see it going higher.. thats ok. Time really isn't an issue, I'm willing to put time in it. I'm patient. I plan on just going with the flow, if I have a strict set plan then I'm going to end up disappointed, right? You know a lot more than I know! I'm learning what i can, when I can. oh, and this may or may not surprise you but I'm 16. (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif) |
Jake Raby |
Save a tad more money and get what you want... Otherwise you will NEVER be satisfied knowing it could be better..
As for service on my engine- It was built from 90% used parts 86K ago and has went up to 18K miles without an oil change AND I have not had to adjust a valve since February 2003! I have checked them every 6 months or so but have not needed to touch a single one yet... Keep in mind that I take this car to driver's ed and have put over 500 track miles on it at WOT above 5500RPM! Longevity and reliability IS NOT IMPACTED by more performance as long as the mathmatics are closely adhered to- Its all in the combo! This engine will last longer than stock, will run cooler than stock and will get equal or better MPG than stock- all while stretching out the RPM range to a more user friendly level and adding power in the upper midrange. Making power doesn't kill the engine! (as long as you do it my way) Hell, on the way through West Virginia I held near 90 MPH for over a solid hour+, it loves it. |
Hammy |
Sounds good.... after viewing the type 4 store and your other sites a whole bunch, I'm thinking - 2056 kit with pre-prepared engine kit assembly option, balance assembly option, and upgrade to ported heads (used?). Would it be a smart idea to add in an engine case for the pre-prepare stage? is a mallory dist. a much needed investment, or what i have now be fine? and you said the camshaft in the kit is chosen according to what induction is used.. would the cam selection end up with any extra cost? |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,000 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
Heat exchangers are the stock type of exhaust. They are essentially two pipes per side, with some metal wrapping around them. Cool air gets blown into one end of the wrapping by the engine cooling fan or the "heater blower" fan, and it gets warmed up by being in contact with the very hot exhaust pipes. It comes out the other side nicely warmed up, and the warm air either gets dumped out there (through the "flapper valves") or piped into the cabin, warming up your toes. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) Headers are, usually in the context of a 914 discussion, a set of carefully designed and fabricated exhaust pipes that are intended for racing. They are generally "tuned" to take advantage of how the exhaust gases flow, and increase power or torque over some specific RPM bands. The good ones make noticeably more power than the stock-type exhaust. However, most of them have no provision whatsoever for heat--and the one that does isn't set up to provide that much heat it seems.
It means someone has taken some grinding implements to the areas of the heads that lead up to the intake valve, and away from the exhaust valve. This can, if done right, increase the flow of the intake gases or exhaust gases through the motor, leading to more power. --DD |
Jake Raby |
I do not charge anything extra for the camshaft swap, its just a matter of changing the intake profile of thecam- no sweat.
The options you listed are really wise ones to choose. |
Hammy |
Thanks DD. Can always expect a good technical explanation from you (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) very helpful.
Jake, around what mpg could one expect from a 2056 with 44 Webers, non-spirited driving? (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
Jake Raby |
As much as 35 is very possible.. I have gotten up to 38
Hammy |
Holy balls.. (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) I was thinking around 20. (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif)
Ok so i'm trying to get some confirmation here, will the used ported heads severely limit engine life as compared to choosing the new ported heads? |
Jake Raby |
This engine is very efficient- as long as you get the tuning correct and keep your foot out of it big mileage is nothing new..
New heads are worth the cost, I am thinking of getting rid of the used ported heads all together.... |
bd1308 |
Sir Post-a-lot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 ![]() |
used heads are crap the old aluminum is cast and of impure quality..... havent seem the new heads, but they seem like they would last a LOT longer..... worth the money in my book...... b |
Jake Raby |
Len and I hand pick the cores we use for these heads, and I have several hundred pair- But with all the work needed to rebuild them correctly it easily adds up to what we have in the new head castings... We still build the heads to our tolerances with all our developed parts, we throw the new stock parts away.
bd1308 |
i've gotta see your engine room in closer detail...that guy, your assistant on the rebuilding the T4 DVD, said that you had like 300 t4 enignes as cores???
thats unbelieveable.....! b |
Lo-Fi Version | Time is now: 25th June 2024 - 10:55 PM |
